IAP Guest WiFi - Tell me why I'm wrong
  • 1.  IAP Guest WiFi - Tell me why I'm wrong
    Posted Oct 09, 2018 06:09 AM
    Hi all,
    So I'm in the process of setting up an IAP WiFi network to deal with corporate WiFi access on SSID1 and guest WiFi on SSID2. I've had no end of issues getting the guest WiFi side of this working, and I've tried virtually every solution I can find with no luck
    The issue: Guest WiFi connects fine but after a few seconds I get "No Internet Connection" seemingly because of a DNS probe fail
    After playing around and not being able to find out where everything's going wrong I've gone with the following solution:
    Local L2 DHCP Scope on the IAP linked to the guest SSID (VCM)
    Network based access rules to ALLOW DHCP, DNS, HTTP/S, SMTP to all destinations
    No deny rules
    This seems to give me exactly what I want. I have a guest WiFi that gives me internet and email access, but doesn't let me ping or RDP to any network devices, no access to network shares etc. But my question is, am I actually getting what I'm seeing? Is there a way someone can still access the corporate network from the guest WiFi that I'm not aware of? Is there any reason for me to explicitly deny access to corporate network subnets if I only have allow specified for certain services?
    So far every time I've tried to include deny rules something breaks the guest WiFi along the way and I just can't find it, so if this setup is secure then I'm not too fussed about tearing the rest of my hair out
  • 2.  RE: IAP Guest WiFi - Tell me why I'm wrong
    Posted Oct 09, 2018 08:48 AM
    There is an implicit deny all at the end for your rules, so if it is not allowed, it is denied. Add a rule to allow everything at the end .
  • 3.  RE: IAP Guest WiFi - Tell me why I'm wrong
    Posted Oct 11, 2018 05:21 AM
    Excellent, thanks for that
    Based off of that I'm going to assume that what I want is working then if there are implicit denies for everything else. I just want users on the guest WiFi to have the ability to browse internet and use email whilst having no access to our corporate network. Sounds like that's what I have :)
