IAP High memory Util. 75%
  • 1.  IAP High memory Util. 75%
    Posted Oct 06, 2016 05:50 AM
    Hi there,
    we monitor one IAP that has regarding Airwave 1 potenital issue. We looked at it, and it reports very hijh Memory Utilization.
    See screenshot. How can this be solves, and or what precautions can we take?
    Currently it has 10 clients. Fixed clietns are in total 7, some guest users it can take up to 15-20 users at the same time. DHCP for fixed users is doen by router, Guest users get IP from IAP DHCP.
  • 2.  RE: IAP High memory Util. 75%
    Posted Oct 06, 2016 06:14 AM
    What is the AP model and version of software it is running?
    In any case, that figure is nothing to be concerned about.  If you see it getting upwards of 85% then you should raise a TAC case.
  • 3.  RE: IAP High memory Util. 75%
    Posted Oct 06, 2016 06:18 AM
    Hi there we are running IAP103
    Coup are running 4.1.3.0 - avg Memory Usage 91MB
    Couple are running 4.1.1.13 - avg Memory Usage 93MB
  • 4.  RE: IAP High memory Util. 75%
    Posted May 18, 2017 04:40 PM
    I am also experiencing this issue and have the following:
    ArubaOS (MODEL: 205), Version 6.5.1.0-4.3.1.1
    13 IAPs in the environment
    High Memory Utilization (90%+ for over 2 weeks now)
    Show Tech gives me the following Memory utilization data:
    CPU and Memory Usage
    Timestamp CPU Util(%) Memory Util(%)
    2017-05-18 11:09:39 17 96
    2017-05-18 11:09:29 10 96
    2017-05-18 11:09:18 21 96
    2017-05-18 11:09:06 16 94
    2017-05-18 11:08:56 18 94
    2017-05-18 11:08:45 12 94
    2017-05-18 11:08:35 15 94
    Peak CPU Util in the last one hour
    2017-05-18 11:07:09 33 95
    The master AP has between 3-8MB of Free Memory and all the other APs in the cluster have 30+MB free.  I've rebooted the master to see if that alleviates any utilization problems.
    I also noticed in the release notes for 6.5.1.0-4.3.1.2 that there's a datapath bug (154065) relating to the issue we're seeing.  Should we still be seeing the high memory utilization on the VC though?
  • 5.  RE: IAP High memory Util. 75%
    Posted May 18, 2017 05:46 PM
    Are you running Apprf?
  • 6.  RE: IAP High memory Util. 75%
    Posted May 19, 2017 03:25 PM
    Yes, we are.  We have the visibility se to ALL.  What is the best practice with the IAP-205 for AppRF visibilty?
    Thank you!
  • 7.  RE: IAP High memory Util. 75%
    Posted Apr 20, 2020 04:11 AM
    Any Follow Up? We have 26 AP-207 showing High Memory in Central with 8.5.0.5 and 8.6.0.4
