IAP Integration with ISE
This thread has been viewed 26 times
  • 1.  IAP Integration with ISE
    Posted Jun 07, 2017 07:43 AM
    Hi Guys,
    I am stucked on something that is beyond my head now. I have a simple lab setup with:
    - Aruba IAP 115 running Version 6.5.3.0
    - Cisco 3750 switch running IOS 12.2(55)SE11 (also configured as DHCP server)
    - CPPM on version 6.6.0.81015 (Integrated with AD)
    - Cisco ISE on version 2.3.x (Integrated with AD)
    - Microsoft AD based on Server 2012
    IAP has been configured with Corporate SSID (802.1x). Intention is to have a policy if a user belongs to AD group "Normal", he will be assigned a user role normal_user/VLAN 50 and if the user belongs to AD group "VIP", he will be assigned the role vip_user/VLAN30.
    This is working as anticipated if I integrate ClearPass with IAP. Users get proper role and VLAN based on group membership.
    For some odd reason this is not working if I integrate IAP with ISE.
    I can see user being authenticated successfully. ISE is passing proper VLAN and user role back to IAP.
    Client disconnects as soon as authentication completes. On IAP, I can see user session with proper role. But for some strange reason, client disconnects as soon as authenticaion completes.
    I would rule out IAP config or client issue as same setup works perfectly fine if I use CPPM as authenticaion server instead of ISE.
    Any thoughts?
    Below are outputs for IAP and ISE:
     6/7/2017 21:48:17 PM    Target: Jibran-Test-IAP    Command: show clients
    Client List
    Name  IP Address  MAC Address        OS  ESSID      Access Point     Channel  Type  Role         IPv6 Address  Signal   Speed (mbps)
          0.0.0.0    14:a5:1a:0e:c4:78      Corporate  Jibran-Test-IAP  11       GN    vip_user     --            0(poor)  0(poor)
          0.0.0.0     ec:9b:f3:3e:ee:aa      Corporate  Jibran-Test-IAP  11       GN    normal_user  --            0(poor)  0(poor)
    Number of Clients   :2
    Info timestamp      :342088
     12304Extracted EAP-Response containing PEAP challenge-response
     11808Extracted EAP-Response containing EAP-MSCHAP challenge-response for inner method and accepting EAP-MSCHAP as negotiated
     15041Evaluating Identity Policy
     15006Matched Default Rule
     15013Selected Identity Source - Jibran-AD
     24430Authenticating user against Active Directory - Jibran-AD
     24325Resolving identity - vip_user
     24313Search for matching accounts at join point - jibran.local
     24319Single matching account found in forest - jibran.local
     24323Identity resolution detected single matching account
     24343RPC Logon request succeeded - vip_user@jibran.local
     24402User authentication against Active Directory succeeded - Jibran-AD
     22037Authentication Passed
     11824EAP-MSCHAP authentication attempt passed
     12305Prepared EAP-Request with another PEAP challenge
     11006Returned RADIUS Access-Challenge
     11001Received RADIUS Access-Request
     11018RADIUS is re-using an existing session
     11810Extracted EAP-Response for inner method containing MSCHAP challenge-response
     11814Inner EAP-MSCHAP authentication succeeded
     11519Prepared EAP-Success for inner EAP method
     12314PEAP inner method finished successfully
     24423ISE has not been able to confirm previous successful machine authentication
     15036Evaluating Authorization Policy
     24432Looking up user in Active Directory - Jibran-AD
     24355LDAP fetch succeeded - jibran.local
     24416User's Groups retrieval from Active Directory succeeded - Jibran-AD
     24420User's Attributes retrieval from Active Directory succeeded - Jibran-AD
     15048Queried PIP - Jibran-AD.ExternalGroups
     15004Matched rule - Aruba Vip User
     15016Selected Authorization Profile - aruba_vip_user,PermitAccess
     12306PEAP authentication succeeded
     11503Prepared EAP-Success
     11002Returned RADIUS Access-Accept
  • 2.  RE: IAP Integration with ISE
    Posted Jun 07, 2017 07:55 AM
    What radius attributes are you returning to set the role and VLAN?
    Also you should manually disconnect the IAP user after you make each change on the ISE side to ensure that old settings are not being reused...
    http://community.arubanetworks.com/t5/Controllerless-Networks/How-to-force-disconnect-a-client-in-Aruba-Central/td-p/294466
  • 3.  RE: IAP Integration with ISE
    Posted Jun 07, 2017 08:08 AM
    Hi Colin,
    Yes I have tried manually disconnecting the user but result remains the same.
    The attributes I am returnign are Aruba-user-role and Aruba-user-VLAN:
    For Normal User:
    Access Type = ACCESS_ACCEPT
    Aruba-User-Role = normal_user
    Aruba-User-Vlan = 50
    For VIP User:
    Aruba-User-Role = vip_user
    Aruba-User-Vlan = 30
  • 4.  RE: IAP Integration with ISE
    Posted Jun 07, 2017 08:10 AM
    Returning same attributes via CPPM and works fine:
    Radius:Aruba:Aruba-User-Rolenormal_user
    Radius:Aruba:Aruba-User-Vlan50
    Radius:Aruba:Aruba-User-Rolevip_user
    Radius:Aruba:Aruba-User-Vlan30
  • 5.  RE: IAP Integration with ISE
    Posted Jun 07, 2017 08:20 AM
  • 6.  RE: IAP Integration with ISE
    Posted Jun 07, 2017 08:30 AM
    Hi Colin,
    Could not find anything unusual except name=null.
    Please find attached.
    Attachment(s)
    txt
    Logs.txt   29 KB 1 version
  • 7.  RE: IAP Integration with ISE
    Posted Jun 07, 2017 08:37 AM
    What is the Mac address of the client?
  • 8.  RE: IAP Integration with ISE
    Posted Jun 07, 2017 08:41 AM
    Its 14:a5:1a:0e:c4:78
  • 9.  RE: IAP Integration with ISE
    Posted Jun 07, 2017 08:50 AM
    It says that your radius server is rejecting the client:
    Jun  7 22:17:44  stm[2633]: <132207> <ERRS> |AP Jibran-Test-IAP@20.0.0.4 stm|  RADIUS reject for station normal_user 14:a5:1a:0e:c4:78 from server CiscoISE.
    Jun  7 22:17:44  stm[2633]: <132053> <ERRS> |AP Jibran-Test-IAP@20.0.0.4 stm|  Dropping the radius packet for Station 14:a5:1a:0e:c4:78 18:64:72:9c:ce:31 doing 802.1x
    Jun  7 22:17:44  cli[2608]: <541003> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  Client 14:a5:1a:0e:c4:78 is failed to authenticate, failure count is 1.
    Jun  7 22:17:46  stm[2633]: stm_send_sta_offline: Sending sta offline msg to CLI0, mac='14:a5:1a:0e:c4:78'
  • 10.  RE: IAP Integration with ISE
    Posted Jun 07, 2017 09:10 AM
    May be that is a typo while entering the password. Cannot see same error on subsequent attempts. Please refer to logs after manually disconecting user @ 23:05:38:
     6/7/2017 23:06:18 PM    Target: Jibran-Test-IAP    Command: show log debug
    Jun  7 22:51:42  stm[2633]: __HIGHER_PRECEDENCE_COMPARE: 1110: matched_rule_index=30008, sap_sta->acl_rule_index=0, precedence_result=1
    Jun  7 22:51:42  stm[2633]: stm_send_sta_update: Sending sta update msg to CLI0, mac='14:a5:1a:0e:c4:78'
    Jun  7 22:51:42  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_stm_sta_update: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:31 essid-Corporate.
    Jun  7 22:51:42  stm[2633]: stm_start_acct_for_post_1xauth_user: 18218: ip not ready for sta '14:a5:1a:0e:c4:78'
    Jun  7 22:51:42  stm[2633]: stm_send_sta_offline: Sending sta offline msg to CLI0, mac='14:a5:1a:0e:c4:78'
    Jun  7 22:51:42  stm[2633]: sap_sta_mac_ppsk_timer_start: 17521: mac ppsk timer start
    Jun  7 22:51:42  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_sta_offline: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:31 essid-Corporate.
    Jun  7 22:51:42  sapd[2627]: sapd_proc_stm_reset_key: Got STM Reset key bss=18:64:72:9c:ce:31 mac=14:a5:1a:0e:c4:78, idx=0
    Jun  7 22:52:00  syslog: main, 2755: opcode is show
    Jun  7 22:52:03  mini_httpd[10298]: handle_request: 2296: SSL_accept fail, child exit after 0 requests error state on socket
    Jun  7 22:52:03  mini_httpd[10299]: handle_request: 2296: SSL_accept fail, child exit after 0 requests error state on socket
    Jun  7 22:52:05  syslog: main, 2755: opcode is show
    Jun  7 22:52:15  syslog: main, 2755: opcode is support
    Jun  7 22:52:15  syslog: process_msg_ref: 22: got msg_ref of len 9750 and body '/tmp/.cli_msg_66Sjmd'
    Jun  7 22:52:15  syslog: process_msg_ref: 47: opening '/tmp/.cli_msg_66Sjmd'
    Jun  7 22:52:15  syslog: process_msg_ref: 52: reading large msg
    Jun  7 22:52:15  syslog: process_msg_ref: 55: read large msg of 9749 bytes
    Jun  7 22:52:30  syslog: main, 2755: opcode is show
    Jun  7 22:53:16  rngd: read=768 bytes_read=0 size=2500
    Jun  7 22:53:30  syslog: main, 2755: opcode is show
    Jun  7 22:53:47  awc[2605]: isc_init: could not resolve 'device.arubanetworks.com'
    Jun  7 22:53:47  awc[2605]: isc_init failed
    Jun  7 22:54:00  syslog: main, 2755: opcode is show
    Jun  7 22:54:21  rngd: read=768 bytes_read=768 size=2500
    Jun  7 22:54:30  syslog: main, 2755: opcode is show
    Jun  7 22:54:32  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_sta_online: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:21 essid-Corporate.
    Jun  7 22:54:32  stm[2633]: recv_radius_acct_multi_session_id: 18172: got mac='14:a5:1a:0e:c4:78', name='(null)', start_time='1496839142 (Wed Jun  7 22:39:02 2017 )'
    Jun  7 22:54:32  sapd[2627]: sapd_proc_stm_reset_key: Got STM Reset key bss=18:64:72:9c:ce:21 mac=14:a5:1a:0e:c4:78, idx=0
    Jun  7 22:54:32  sapd[2627]: <127038> <WARN> |AP Jibran-Test-IAP@20.0.0.4 sapd| |ids-ap| AP(18:64:72:9c:ce:20): Cleared Station Associated to Rogue AP: An AP is no longer detecting a client 14:a5:1a:0e:c4:78 associated to a rogue access point (BSSID 88:a6:c6:98:dc:c8 and SSID Cisco on CHANNEL 1).
    Jun  7 22:54:32  stm[2633]: iap_fmt_called_station_id: Called Station ID Type is (0)
    Jun  7 22:54:32  stm[2633]: iap_fmt_called_station_id: Called Station ID buffer is (186472c1cce2)
    Jun  7 22:54:32  stm[2633]: __HIGHER_PRECEDENCE_COMPARE: 1110: matched_rule_index=30008, sap_sta->acl_rule_index=0, precedence_result=1
    Jun  7 22:54:32  stm[2633]: stm_send_sta_update: Sending sta update msg to CLI0, mac='14:a5:1a:0e:c4:78'
    Jun  7 22:54:32  stm[2633]: stm_start_acct_for_post_1xauth_user: 18218: ip not ready for sta '14:a5:1a:0e:c4:78'
    Jun  7 22:54:32  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_stm_sta_update: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:21 essid-Corporate.
    Jun  7 22:54:32  stm[2633]: stm_send_sta_offline: Sending sta offline msg to CLI0, mac='14:a5:1a:0e:c4:78'
    Jun  7 22:54:32  stm[2633]: sap_sta_mac_ppsk_timer_start: 17521: mac ppsk timer start
    Jun  7 22:54:32  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_sta_offline: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:21 essid-Corporate.
    Jun  7 22:54:59  syslog: main, 2755: opcode is show
    Jun  7 22:55:26  rngd: read=768 bytes_read=1536 size=2500
    Jun  7 22:55:29  syslog: main, 2755: opcode is show
    Jun  7 22:56:29  syslog: main, 2755: opcode is show
    Jun  7 22:56:31  rngd: read=768 bytes_read=2304 size=2500
    Jun  7 22:56:31  rngd: 3072 bytes read from TPM
    Jun  7 22:56:59  syslog: main, 2755: opcode is show
    Jun  7 22:57:29  syslog: main, 2755: opcode is show
    Jun  7 22:58:53  awc[2605]: isc_init: could not resolve 'device.arubanetworks.com'
    Jun  7 22:58:53  awc[2605]: isc_init failed
    Jun  7 22:59:00  syslog: main, 2755: opcode is show
    Jun  7 23:00:00  syslog: main, 2755: opcode is show
    Jun  7 23:01:30  syslog: main, 2755: opcode is show
    Jun  7 23:03:00  syslog: main, 2755: opcode is show
    Jun  7 23:03:55  awc[2605]: isc_init: could not resolve 'device.arubanetworks.com'
    Jun  7 23:03:55  awc[2605]: isc_init failed
    Jun  7 23:04:00  syslog: main, 2755: opcode is show
    Jun  7 23:05:00  syslog: main, 2755: opcode is show
    Jun  7 23:05:33  mini_httpd[11874]: handle_request: 2296: SSL_accept fail, child exit after 0 requests error state on socket
    Jun  7 23:05:34  mini_httpd[11875]: handle_request: 2296: SSL_accept fail, child exit after 0 requests error state on socket
    Jun  7 23:05:35  syslog: main, 2755: opcode is show
    Jun  7 23:05:38  syslog: main, 2755: opcode is action
    Jun  7 23:05:38  cli[2608]: <341101> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  Execute command-disconnect-user mac 14:a5:1a:0e:c4:78.
    Jun  7 23:05:38  cli[2608]: <541023> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  disconnect_user,20713: del client 14:a5:1a:0e:c4:78, client count 0.
    Jun  7 23:05:38  cli[2608]: <541026> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  disconnect_user: send disconnect user, AP ip: 20.0.0.4, client ip 30.0.0.7.
    Jun  7 23:05:38  stm[2633]: handle_disconnect_user: 10055: Cannot find sta infor for sta '14:a5:1a:0e:c4:78'
    Jun  7 23:05:39  syslog: main, 2755: opcode is show
    Jun  7 23:05:44  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_sta_online: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:31 essid-Corporate.
    a_online,1246: add client 14:a5:1a:0e:c4:78, client count 1.
    Jun  7 23:05:44  stm[2633]: recv_radius_acct_multi_session_id: 18172: got mac='14:a5:1a:0e:c4:78', name='(null)', start_time='1496840743 (Wed Jun  7 23:05:43 2017 )'
    Jun  7 23:05:44  sapd[2627]: sapd_proc_stm_reset_key: Got STM Reset key bss=18:64:72:9c:ce:31 mac=14:a5:1a:0e:c4:78, idx=0
    Jun  7 23:05:44  stm[2633]: iap_fmt_called_station_id: Called Station ID Type is (0)
    Jun  7 23:05:44  stm[2633]: iap_fmt_called_station_id: Called Station ID buffer is (186472c1cce2)
    Jun  7 23:05:48  mini_httpd[11912]: handle_request: 2296: SSL_accept fail, child exit after 0 requests error state on socket
    Jun  7 23:05:49  mini_httpd[11913]: handle_request: 2296: SSL_accept fail, child exit after 0 requests error state on socket
    Jun  7 23:05:49  stm[2633]: iap_fmt_called_station_id: Called Station ID Type is (0)
    Jun  7 23:05:49  stm[2633]: iap_fmt_called_station_id: Called Station ID buffer is (186472c1cce2)
    Jun  7 23:05:49  stm[2633]: __HIGHER_PRECEDENCE_COMPARE: 1110: matched_rule_index=30008, sap_sta->acl_rule_index=0, precedence_result=1
    Jun  7 23:05:49  stm[2633]: stm_send_sta_update: Sending sta update msg to CLI0, mac='14:a5:1a:0e:c4:78'
    Jun  7 23:05:49  stm[2633]: stm_start_acct_for_post_1xauth_user: 18218: ip not ready for sta '14:a5:1a:0e:c4:78'
    Jun  7 23:05:49  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_stm_sta_update: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:31 essid-Corporate.
    Jun  7 23:05:49  stm[2633]: stm_send_sta_offline: Sending sta offline msg to CLI0, mac='14:a5:1a:0e:c4:78'
    Jun  7 23:05:49  stm[2633]: sap_sta_mac_ppsk_timer_start: 17521: mac ppsk timer start
    Jun  7 23:05:49  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_sta_offline: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:31 essid-Corporate.
    Jun  7 23:05:49  sapd[2627]: sapd_proc_stm_reset_key: Got STM Reset key bss=18:64:72:9c:ce:31 mac=14:a5:1a:0e:c4:78, idx=0
    Jun  7 23:05:53  syslog: main, 2755: opcode is show
    Jun  7 23:06:17  syslog: main, 2755: opcode is support
  • 11.  RE: IAP Integration with ISE
    Posted Jun 07, 2017 09:59 AM
    That log is inconclusive.  Did you try to just send back an accept without the radius attributes? (start small)..
  • 12.  RE: IAP Integration with ISE
    Posted Jun 07, 2017 10:02 AM
    Yes I tried.. Same result.
  • 13.  RE: IAP Integration with ISE
    Posted Jun 07, 2017 10:16 AM
    I would do a pcap between the IAP and the ISE server of the radius packets to see what is being passed back and forth...
  • 14.  RE: IAP Integration with ISE
    Posted Jun 08, 2017 08:54 AM
    Hi Colin,
    I have done hte packet capture and it looks like IAP is receiving Access-Accept message with correct attributes. Also attached PCAP file if you can go throgh it. ISE IP Address is 192.168.0.205 & IAP is 20.0.0.4
    Frame 585: 395 bytes on wire (3160 bits), 395 bytes captured (3160 bits)
    Ethernet II, Src: Vmware_0d:4f:fd (00:0c:29:0d:4f:fd), Dst: CiscoInc_04:52:c0 (30:37:a6:04:52:c0)
    Internet Protocol Version 4, Src: 192.168.0.205, Dst: 20.0.0.4
    User Datagram Protocol, Src Port: 1812, Dst Port: 49566
    RADIUS Protocol
        Code: Access-Accept (2)
        Packet identifier: 0x81 (129)
        Length: 353
        Authenticator: 8751b2479ac9dcb4ce07ae88ed015d28
        [This is a response to a request in frame 584]
        [Time from request: 0.015640000 seconds]
        Attribute Value Pairs
            AVP: l=10 t=User-Name(1): vip_user
            AVP: l=67 t=State(24): 52656175746853657373696f6e3a63306138303063645274...
            AVP: l=88 t=Class(25): 434143533a63306138303063645274767770386556675f64...
            AVP: l=6 t=EAP-Message(79) Last Segment[1]
            AVP: l=18 t=Message-Authenticator(80): c11d6eb4c5e508372dbad472440f3b0d
            AVP: l=58 t=Vendor-Specific(26) v=Microsoft(311)
            AVP: l=12 t=Vendor-Specific(26) v=Aruba Networks Inc(14823)
                AVP Type: 26
                AVP Length: 12
                VSA: l=6 t=Aruba-User-Vlan(2): 30
                    Aruba-User-Vlan: 30
            AVP: l=16 t=Vendor-Specific(26) v=Aruba Networks Inc(14823)
                AVP Type: 26
                AVP Length: 16
                VSA: l=10 t=Aruba-User-Role(1): vip_user
                    Aruba-User-Role: vip_user
    Uploaded PCAP file at below link:
    http://s000.tinyupload.com/?file_id=01020657595839532534
  • 15.  RE: IAP Integration with ISE
    Posted Jun 08, 2017 09:11 AM
    Also, for the sake of troubleshooting, I kept everything unchanged except replacing ISE with CPPM as RADIUS server on IAP. As expected, eveything worked well. CPPM IP Address is 192.168.0.207. PCAP uploaded at below link:
    http://s000.tinyupload.com/?file_id=73346906703880133266
  • 16.  RE: IAP Integration with ISE
    Posted Jun 10, 2017 06:10 AM
    Any clue guys?
  • 17.  RE: IAP Integration with ISE
    Posted Sep 12, 2017 04:16 AM
    Has this case already been resolved? Also do you have a step by step guide how to do this Cisco ISE and Aruba IAP integration?
  • 18.  RE: IAP Integration with ISE
