IAP Internal Captive Portal
  • 1.  IAP Internal Captive Portal
    Posted Feb 21, 2017 03:51 AM
    We have several IAP205, conencted to an Airwave server. We want to configure 2 x SSID, one using internal Captive Portal authenticated against LDAP, one using internal Captive Portal acknowledged. Is is possible? Is it only one internal Captive Portal available? Any way to have multiple? Thanks.
  • 2.  RE: IAP Internal Captive Portal
    Posted Feb 21, 2017 06:18 AM
    Yes, Each SSID can use the internal captive portal for different purposes
    Get Outlook for iOS
  • 3.  RE: IAP Internal Captive Portal
    Get Outlook for iOS
