IAP IPSEC VPN L2 Centralized - Unable to get DHCP
  • 1.  IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 15, 2019 02:24 PM
    I am trying to setup an L2 Centralized IAP VPN configuration and running into issues.
    I have the IAP with a IPSec Tunnel and the tunnel is up. I can see the SA active session in show crytpo isakmp sa.
    I created a generic PSK network for testing and connect to it, but the DHCP Discover never gets answered.
    I mapped the DHCP server as a VLAN on the controller.
    I feel like I'm missing a step on the controller to tell it to utilize the VLAN as part of the tunnel but I'm not finding this in the VRD.
    Thanks for any help!
  • 2.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 15, 2019 03:36 PM
    I will advise you to take a look in the documentation.
    https://www.arubanetworks.com/techdocs/Instant_83_WebHelp/Content/Instant_UG/IAP_VPN/IAP_VPN_Support.htm
    Make sure you use the same VLAN ID within the SSID/DHCP profile configuration and the controller side. So the VLAN specified in the IAP is the VLAN where the device is placed into.
  • 3.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 16, 2019 09:47 AM
    Thanks for that document, it is exactly what I was looking for to setup.
    However, I've gone through it and still have the same issue.
    Users
    IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile Forward mode Type Host Name User Type
    172.16.10.80 00:00:00:00:00:00 20:a6:cd:cf:e8:e2 default-vpn-role 02:23:41 VPN 10.18.250.74 N/A default-iap tunnel WIRELESS
    I did notice within the document to create a role and have done that, but it appears my IAP is still using the default-vpn-role. I feel like this is only necessary for the RADIUS src-nat piece, though. Right now I'm just trying to get it working with PSK.
    Thanks for the help
  • 4.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 16, 2019 10:07 AM
    In the past you could change the user roles for IAP-VPN. Today this is only possible if you have the VPN license.
  • 5.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 16, 2019 10:26 AM
    Does this mean for my scenario, L2 Centralized with central RADIUS I need that license?
  • 6.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 16, 2019 10:34 AM
    No, but if you need to assign different user roles to the IAP-VPN user than you need a license
  • 7.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 16, 2019 10:42 AM
    I don't believe I will, but since it still isn't working I'm confused where the gap is.
  • 8.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 16, 2019 03:09 PM
    Okay, I found that I needed to add the mac address to the trusted branch db. I didn't see that in the documentation as it only seemed to mention adding to the whitelist.
    I now see the IAP when I do show iap detailed-table.
    It shows that the Status is up with Primary, Centralized and Bridged(L2) flags. However, still cannot connect as a client. DHCP and Arp do not respond.
  • 9.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 16, 2019 03:14 PM
    Do you see the devices with the command "show station-table". Please also use the following commands to see if the device is connected and placed in the correct network.
    show user-table mac
    show datapath bridge table
    Is the IAP VLAN (configured within the IAP SSID configured) available at the controller?
  • 10.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 16, 2019 03:24 PM
    Here is the output for show user-table
    Users
    172.16.10.80 00:00:00:00:00:00 20:a6:cd:cf:e8:e2 default-vpn-role 03:05:18 VPN 10.18.250.74 N/A default-iap tunnel WIRELESS
    10.18.250.74 00:00:00:00:00:00 logon 03:05:18 VPN N/A tunnel WIRELESS
    I'm confused by that logon role entry, and I do not see my laptop mac.
    There was nothing in datapath bridge table for my mac either.
    The VLAN is available on the controller and is also used for local wireless. Do I need to change this and have a separate VLAN?
  • 11.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 16, 2019 03:30 PM
    I had seen some issues in the past with the IAP VPN when placing users in the same VLAN as 'normal' CAP users. After separating the CAP and IAP users the issues was fixed. Could you try this?
    The users only appear in the user table if they will have an IP address.
    Because the user is also not in the bridge table there is an issue with the datapath.
  • 12.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 16, 2019 04:57 PM
     I tried a different VLAN (one that is used for RAP wired connections). Still no change.
  • 13.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 17, 2019 08:41 AM
    Looking over things, I'm wondering if the issue is related to the routing profile. I have it set to 0.0.0.0/0.0.0.0 with a next hop of the controller's IP for the VPN. Is this correct? I'm not quite seeing in the document how to set the route for all traffic to go over the tunnel.
  • 14.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Apr 17, 2019 02:07 PM
    A routing profile is not needed because it’s a L2 iap VPN.
    Could you share a tech support from the IAP and controller? You can send me a PM
  • 15.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Jul 05, 2019 01:29 PM
    Do you have some news, I've got the same problem too :(
  • 16.  RE: IAP IPSEC VPN L2 Centralized - Unable to get DHCP
    Posted Jul 05, 2019 09:03 PM
    make sure you are using Aruba IPsec as the VPN protocol,
    Also check the routing profile settings in this technote.
    https://community.arubanetworks.com/t5/Controllerless-Networks/IAP-VPN-Centralised-L2-and-Distributed-L3-with-3G-4G-pre-emption/td-p/528954
