IAP Issue
  • 1.  IAP Issue
    Posted Nov 05, 2015 02:23 AM
    We have IAP- 225 which was earlier converted to CAP with the Vlan X vrrp ip. Now we changed the vrrp vlan to Y and vip got changed. Now how to change and convert the IAP earlier config.. we are unable to take GUI as we have connected to POE switch and eth1 port is getting disabled.
    #AP225
  • 2.  RE: IAP Issue
    Posted Nov 05, 2015 05:42 AM
    When an IAP is converted to a CAP, the ip address you pointed it to is provisioned into the CAP and it always points to that address, unless you change it.  If it can no longer find the controller, you must either:
    1 - Get into the CAP using a console cable and stop it at the "apboot" prompt and change the master to the new address by doing:
    setenv master <new master ip address>
    save
    boot
    or:
    2 - Using the reset button and then converting it to a CAP again using the new VRRP address.
    Only plug in the AP in using ethernet0.
