IAP joins Mesh but not Cluster
  • 1.  IAP joins Mesh but not Cluster
    Posted Sep 09, 2019 08:11 AM
    We're demoing out first wireless mesh using IAP 374 on ver 8.5.0.3
    I made sure all the IAPs are on the same version, and joined the cluster prior to being deployed to their current location.
    I have 1 AP acting as the portal, feeding 2 points. One of the points has joined the mesh and cluster correctly.
    The Other point can be pinged sometimes, and can be seen on the portal when running 'show ap mesh link', but does not join the cluster.
    I had factory reset the point and reployed it a couple times, but no luck.
    It did join the cluster once, but could not be managed, and shortly left the cluster.
    Show log system had the following ( I took image.pnga screenshot didnt save it as text, my bad).
    *edit*
    I've just SSH'd to the IAP that isn't joining the cluster over the mesh, here's what I get in it's log system, to provide more info:
    Sep 9 07:31:48 nanny[3983]: <303073> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Process /usr/sbin/dhcp-helper [pid 16962] died: got signal SIGTERM
    Sep 9 07:31:48 nanny[3983]: <303079> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Restarted process /usr/sbin/dhcp-helper, new pid 17009
    Sep 9 07:31:48 cli[4049]: <341004> <WARN> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 cli| Swarm State Change from Startup to Found
    Sep 9 07:31:58 nanny[3983]: <303073> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Process /usr/sbin/dhcp-helper [pid 17009] died: got signal SIGTERM
    Sep 9 07:31:58 nanny[3983]: <303079> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Restarted process /usr/sbin/dhcp-helper, new pid 17066
    Sep 9 07:31:59 cli[4049]: <341004> <WARN> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 cli| Swarm State Change from Startup to Found
    Sep 9 07:32:08 nanny[3983]: <303073> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Process /usr/sbin/dhcp-helper [pid 17066] died: got signal SIGTERM
    Sep 9 07:32:08 nanny[3983]: <303079> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Restarted process /usr/sbin/dhcp-helper, new pid 17129
    Sep 9 07:32:09 cli[4049]: <341004> <WARN> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 cli| Swarm State Change from Startup to Found
    Sep 9 07:32:18 nanny[3983]: <303073> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Process /usr/sbin/dhcp-helper [pid 17129] died: got signal SIGTERM
    Sep 9 07:32:18 nanny[3983]: <303079> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Restarted process /usr/sbin/dhcp-helper, new pid 17182
    <303073> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Process /usr/sbin/dhcp-helper [pid 17182] died: got signal SIGTERM
    Sep 9 07:32:28 nanny[3983]: <303079> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Restarted process /usr/sbin/dhcp-helper, new pid 17239
    Sep 9 07:32:29 cli[4049]: <341004> <WARN> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 cli| Swarm State Change from Startup to Found
    Sep 9 07:32:38 nanny[3983]: <303073> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Process /usr/sbin/dhcp-helper [pid 17239] died: got signal SIGTERM
    Sep 9 07:32:38 nanny[3983]: <303079> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Restarted process /usr/sbin/dhcp-helper, new pid 17296
    Sep 9 07:32:39 cli[4049]: <341004> <WARN> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 cli| Swarm State Change from Startup to Found
    Sep 9 07:32:48 nanny[3983]: <303073> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Process /usr/sbin/dhcp-helper [pid 17296] died: got signal SIGTERM
    Sep 9 07:32:48 nanny[3983]: <303079> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Restarted process /usr/sbin/dhcp-helper, new pid 17349
    Sep 9 07:32:49 cli[4049]: <341004> <WARN> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 cli| Swarm State Change from Startup to Found
    Sep 9 07:32:58 nanny[3983]: <303073> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Process /usr/sbin/dhcp-helper [pid 17349] died: got signal SIGTERM
    Sep 9 07:32:58 nanny[3983]: <303079> <ERRS> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 nanny| Restarted process /usr/sbin/dhcp-helper, new pid 17406
    Sep 9 07:32:59 cli[4049]: <341004> <WARN> |AP 80:8d:b7:cf:8e:ea@10.134.1.11 cli| Swarm State Change from Startup to Found
  • 2.  RE: IAP joins Mesh but not Cluster
    Posted Sep 10, 2019 10:51 AM
    After another factory reset and reconfiguring the IAP, it joined the cluster and mesh
