We are having issue the IAP that managed by Airwave detect down. We need to manually reboot the ap at site in order to work back.This issue is a daily issue.Is there any troubleshooting guide on instant ap connectivity?also noticed from airwave that cluster ap got 1 possible issue which low uptime.
There could be many reasons for this. See if you can SSH into the VC when it says that it is down. If you can, type "show log system" to see what could be the problem. If you are powering it over POE, make sure it continues to be powered properly.
