  • 1.  IAP Licenses
    Posted Oct 10, 2011 07:00 AM
    Hello. I am working on producing a network design for the implimentation of IAP's. (I should add that I am not an Aruba expert and have never seen these devices so therefore these may be silly questions)
    In the past I have only every designed around AP's + Controller environments. To purchase an IAP, is it necessary to purchase single licenses with it - PEFNG, RFP etc. or do these come with a single license installed.
    If in the future it is necessary to change the firmware and hang these off a convenvtional controller, how much is involved in the upgrade? many thanks.
  • 2.  RE: IAP Licenses
    Posted Oct 10, 2011 07:05 AM
    Welcome!
    Once you purchase and IAP you do not need to purchase anything additional UNLESS you convert it and connect it to a controller. If you do, the controller needs to be licensed. In the future it is necessary to point them to a controller to make that IAP controller-based. There is a tab in the IAP that lets you point it to a controller and it will do the upgrade and reboot.
  • 3.  RE: IAP Licenses
    Posted Oct 25, 2016 02:25 AM
    Hi
    This seems not to be true: you won't be able to get any (security) fixes. You can only get new firmware when you buy some sort of support contract.
    regards,
    Frank
  • 4.  RE: IAP Licenses
    Posted Oct 25, 2016 06:55 AM
    You receive all GA releases for free. Early deployment code does require support.
  • 5.  RE: IAP Licenses
    Posted Oct 25, 2016 07:45 AM
    @fkorpershoek wrote:
    Hi
    regards,
    Frank
    To be clear, security fixes are certainly included.  All Limited Lifetime Warranty can be downloaded here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=21997
  • 6.  RE: IAP Licenses
    Posted Oct 25, 2016 08:08 AM
    Hi cjoseph,
    Via the website I found a firmware update which was not accesible for me. I created a support ticket and the reponse from Aruba Support was that I should have a valid support contract to be able to get it. In some other thread in this forum I found the above URL which indeed enabled me to get the latest bits. Luckily my device is now running updated :-) If Aruba Support had know this, it would have saved me some frustration ;-) Anyway, thanks for your response.
    regards, Frank
  • 7.  RE: IAP Licenses
    Posted Oct 10, 2011 07:19 AM
    Many thanks for the quick reply... no doubt I will be bouncing many other questions of the forum in due coarse.
