IAP - Limit the Number of User Per AP
  • 1.  IAP - Limit the Number of User Per AP
    Posted Dec 02, 2013 01:12 AM
    Hi Friends,
    Can we limit number of users per AP in virtual controller setup.?
  • 2.  RE: IAP - Limit the Number of User Per AP
    Posted Dec 02, 2013 05:59 AM
    You can do it per service (SSID). There's a max clients threshold in the wlan settings (the first page in your SSID setup). Click advanced options at the bottom of the page to see it.
    Don't think it's possible per AP.
    Having said that, this generally isn't a good idea. What are you trying to achieve or prevent in real world terms?
  • 3.  RE: IAP - Limit the Number of User Per AP
    Posted Dec 02, 2013 06:51 AM
    We have seen the option to set maximum client threshold on per BSSID base but we want only 15 user per AP so that user gets maximum available bandwidth.
  • 4.  RE: IAP - Limit the Number of User Per AP
    Posted Dec 02, 2013 09:34 AM
    If you are running role based access and 4.0, you can implement bandwidth contracts per user.
  • 5.  RE: IAP - Limit the Number of User Per AP
    Posted Dec 03, 2013 01:40 AM
    Thanks, It seem that would be the only solution. Thanks for your feedback
