IAP loopback address
  • 1.  IAP loopback address
    Posted Mar 23, 2017 07:07 AM
    I am trying to add a new IAP to a cluster. The IAP joins the cluster with DHCPO enabled but when I try to statically assign an IP address I get this error - "Loopback address is not allowed". I have tried on the CLI as well with the same result.
    Any ideas?
  • 2.  RE: IAP loopback address
    Posted Mar 23, 2017 07:22 AM
    Screenshot of the error, please.
  • 3.  RE: IAP loopback address
    Posted Mar 23, 2017 07:25 AM
    Unable to get a screenshot, but after typing in the IP address command on the cli it simply returns -
    In the web gui its a browser pop-up that says the same thing.
  • 4.  RE: IAP loopback address
    MVP EXPERT
    Posted Mar 23, 2017 07:31 AM
    Hi, do you have any IP address conflicts? I.e the IAP IP and the VC IP? If you can paste the command you are running that would be great :)
  • 5.  RE: IAP loopback address
    Posted Mar 23, 2017 07:38 AM
    Its on a standalone laptop connected to a switch that we use for setting up stores IAPs to send out - so no connection to the internet or any other networks which is why I couldn't get a screenshot. There are no IP address conflicts - I'm pretty sure of this because there are only a couple of IPs on the network - the laptop address which runs the DHCP server, the master IAP and the VC IP address. The address we were trying to configure the new IAP was not any of these ones.
