Network Management
IAP management in Airwave iap clusters
  • 1.  IAP management in Airwave iap clusters
    Posted Jan 19, 2016 08:33 AM
    Hi community,
    I´ve a deployment with some instant clusters, in airwave I have a group for every location eg Orlando,Berlin,Rom and so on. The instants are managed in airwave (instant config). Is it possible to deploy a new ssid over all groups (locations) or is it possible to copy config snippets from one group to an other and I must not configure the ssid on all groups?
    Thanks a lot.
  • 2.  RE: IAP management in Airwave iap clusters
    Posted Jan 19, 2016 02:23 PM
    Hi Leon, there is no pure way to do that across all groups. The premise of a group is that it has unique properties (config, profiles, IP's etc) that are different and thus require a different management group. Otherwise you'd have one group and one global config.
    That said, if the baseline of your config is the same - I'd consider making a new group via templates then importing the config from an existing device - then edit your group specific variables. At this point you could enable IGC by editing the group management values.
    Cheers, Adam
