IAP maneged through cloud
  • 1.  IAP maneged through cloud
    Posted Oct 15, 2014 08:45 AM
    have a good day ,
    please i have a senario and need confirmation on solution
    we have 30 warehouse located in different location each one contain 2 IAP and need to managed from one central point so  we will have 30 cluster
    my solution is to have 30  SUB1-CNP-IAP-1  ......
    please advice
    thanks ,
    Ehab Atef
    Network Engineer
    CCNA ,CWNA ,ACMA
  • 2.  RE: IAP maneged through cloud
    Posted Oct 15, 2014 08:51 AM
    What is the total AP count? 30 or 60?
  • 3.  RE: IAP maneged through cloud
    Posted Oct 15, 2014 08:54 AM
    Total AP = 60 but total virtual controler = 30
    can i managed each location from the virtial controler AP ?
    Thanks ,
    Ehab Atef
  • 4.  RE: IAP maneged through cloud
    Posted Oct 15, 2014 08:56 AM
    You need 60 licenses then. It's per-AP not per VC
  • 5.  RE: IAP maneged through cloud
    Posted Oct 15, 2014 09:09 AM
    is the best solution for managing 30 remote location from one site ?
    thanks ,
    Ehab Atef
    Network Engineer
    ACMA ,CCNA ,CWNA
  • 6.  RE: IAP maneged through cloud
    Posted Oct 15, 2014 09:11 AM
    It depends.
    Airwave may be cheaper long term since Central is a yearly subscription.
    Do you have an Aruba account team?
  • 7.  RE: IAP maneged through cloud
    Posted Oct 15, 2014 09:20 AM
    yes i have Aruba Acount team ?
    we are a Aruba  Distrubuter for egypt
    Airwave can manage AP through cloud ? how ?
    please Advice .
  • 8.  RE: IAP maneged through cloud
    Posted Oct 15, 2014 09:27 AM
    Well you would install Airwave on-premise or in your datacenter and Instant APs talk back to it. It's more of a private cloud.
