IAP Mesh with RAP109 and eth0 bridging
  • 1.  IAP Mesh with RAP109 and eth0 bridging
    MVP GURU
    Posted Dec 19, 2017 09:59 AM
    I try to make a IAP Mesh with IAP-203 and RAP109 and use the eth0 of RAP109
    I have enable the eth0-bridging and set a wired profile
    Work on eth1 but don't work eth0
    Any idea ?
  • 2.  RE: IAP Mesh with RAP109 and eth0 bridging
    Posted Jan 09, 2018 06:37 PM
    you brought them both up on the wire with the same VC first correct?
  • 3.  RE: IAP Mesh with RAP109 and eth0 bridging
    MVP GURU
    Posted Jan 10, 2018 04:07 AM
    Yes
  • 4.  RE: IAP Mesh with RAP109 and eth0 bridging
    Posted Jan 10, 2018 12:14 PM
    I would open a TAC case then so they can look at the details of your setup.config, or you can post your two AP's configs here (via CLI) and someone can look at them to see if something is missing. If the extensed SSID is disabled and the eth0 bridge is setup correctly, the first thing to check is if the mesh is up. If yes but Eth0 won't bridge, then it's likely an eth0 config issue or something with the port/config on the external device.
  • 5.  RE: IAP Mesh with RAP109 and eth0 bridging
    MVP GURU
    Posted Jan 10, 2018 04:18 PM
    Yes, Mesh work on enet/eth1
    i will be open a case
  • 6.  RE: IAP Mesh with RAP109 and eth0 bridging
    Posted Jan 10, 2018 04:48 PM
    The mesh should work regardless of ethernet config (assuming you power the mesh point with external power supply).
