Hi all, Im doing some testing with multicast in my iap (8.5.0.2)
So I have setup a stream (with VLC) between a wireless and wired client on the same VLAN and can see the stream using the show ip igmp command on the cli.
But the results I have are not quite what I expected.
Here are my results with different SSID settings:
Setting 1:Broadcast filtering
DisabledMulticast transmission optimalization
DisabledDynamic multicast optimalization
Disabled.
Airgroup settings:
AllowALLResult: multicast stream is not working
So here I expected to multicast to work because broadcast filtering is disabled. (and I read in the manual that it is used for multicast as well)
Setting 2:
Broadcast filtering
EnabledDynamic multicast optimalization
Disabled
Airgroup settings: AllowALLResult: multicast stream is not working
Setting 3:
Disabled
As expected the stream works with all different settings if "broadcast filtering" because its converted from multicast to unicast.
So I'm not sure why setting 1 and 2 are not working. Some tips and tricks here?
James -
