IAP Multiple External Captive Portal Pages?
  • 1.  IAP Multiple External Captive Portal Pages?
    MVP
    Posted Oct 23, 2013 01:33 PM
    Hi all,
    So I have a client who wants to have 2 SSID's for guest. 1 with a splash page that only requests the user agree to the terms and they are on, the other they want to have a Sponsored Guest form. We have implemented ClearPass and setup all services on CPPM and Guest. However, when we try to define the external captive portal URL on the IAP, it seems to only allow one, if we type a different one in the other SSID it will change for both. Can we only have 1 external captive portal page per VC?
    Thanks!
  • 2.  RE: IAP Multiple External Captive Portal Pages?
    Posted Oct 23, 2013 01:38 PM
    As fo today, we can only support one CP profile. However, there is another post here on Airheads with using some ClearPass magic to create more than one.
    Basically, the URL redirect is pointed to a page on CPPM.  CPPM based on the SSID redirects it to the "real" intended page.  See here:
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Different-captive-portal-for-each-SSID/m-p/96149
  • 3.  RE: IAP Multiple External Captive Portal Pages?
    MVP
    Posted Oct 23, 2013 01:39 PM
    Awesome thanks!
  • 4.  RE: IAP Multiple External Captive Portal Pages?
    Posted Oct 23, 2013 08:26 PM
    And native support for multiple captive portals will be in next version (IAP4.0)
