IAP NPS authentication problems
  • 1.  IAP NPS authentication problems
    Posted Oct 20, 2014 03:23 PM
    we have some iap103 firmware Instant_Pegasus_6.4.2.0-4.1.1.0_46028 on it.
    I want to authenticate one ssid with a ms nps (server 2012r2) against our active directory.
    The NPS Server shows the following error:
    Reason Code: 21
    Reason: An NPS extension dynamic link library (DLL) that is installed on the NPS server rejected the connection request.
    what is the problem?
  • 2.  RE: IAP NPS authentication problems
    Posted Oct 20, 2014 04:19 PM
    Do you have any third party authentication agents installed on your server ?
  • 3.  RE: IAP NPS authentication problems
    Posted Oct 20, 2014 04:37 PM
    Yes there is a SMS applications in it.
    That usw the NPS too.
  • 4.  RE: IAP NPS authentication problems
    Posted Oct 20, 2014 04:47 PM
    That might be your issue , I had a similar issue with a safenet agent
  • 5.  RE: IAP NPS authentication problems
    Posted Oct 23, 2014 03:24 AM
    yes, the third p. agent has blockt it...
    thanks a lot.
