Cloud Managed Networks
IAP on Central change Static ip to DHCP Assigned
  • 1.  IAP on Central change Static ip to DHCP Assigned
    Posted Sep 18, 2018 11:41 PM
    Hi, everyone:
    I have some IAP's with static IP configured and registered on Central .When an outage occurs and IAP's startup again they gets an IP DHCP assigned.
    This behavior started a month ago.
    the firmware is 6.5.4.7_64552 and this issue is on different platforms (215, 315)
  • 2.  RE: IAP on Central change Static ip to DHCP Assigned
    Posted Sep 19, 2018 04:19 AM
    Thats sounds like a nasty bug. The recommended IAP version is 8.3.0.1_65474, but latest version 6 is 6.5.4.8. Nothing in the release notes of a fix to that, but several other DHCP related issues was solved there. Might be worth doing an upgrade, but you should also contact Aruba TAC to get it looked at.
  • 3.  RE: IAP on Central change Static ip to DHCP Assigned
    Posted Sep 19, 2018 10:22 AM
    Thanks for your answer, John:
    Just to be clear, this behavior is not present on all AP's with the same fimware version registered to Central.
    Do you recommend to apply an upgrade to the 8.3.0.1_65474, anyway?
    I have a ticket since one month ago, escalled to L3, they already review the logs and watch this behavior in live, but they said that not seen nothing unusuall.
  • 4.  RE: IAP on Central change Static ip to DHCP Assigned
    Posted Sep 19, 2018 10:26 AM
    I would not hesitate to upgrade to the latest 6 version, but for 8.3 you might want to consult Aruba TAC first. We have done it several places and it have worked well, but it is a major upgrade so...
