IAP - Over 128AP
  • 1.  IAP - Over 128AP
    Posted Aug 08, 2019 01:39 AM
    I have over 128IAP to design together with Aruba Central on a single site, they are looking for a cloud based deployment so i can't have a controller deployment for this one. Would the multi cluster work on this one? How would is the behavior of the client when roaming to differnet cluster if the device is already authenticated?
    For aruba central deployment for me to get the single config for multi cluster i would group all the ap in to a single group. is this correct?
  • 2.  RE: IAP - Over 128AP
    Posted Aug 08, 2019 02:13 AM
    you can have two Instant clusters and both being part of the same Aruba Central group assumng they have common configation or have each of them in their own group.
