Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
IAP PPPoE VLAN
  • 1.  IAP PPPoE VLAN
    Posted Aug 01, 2022 01:38 PM
    Hello guys,
    This is my first post here on Aruba Community, but you guys already help me a lot while setting up Aruba devices and software.
    I'm trying to setup an Aruba AP-203R in Instant AP mode to dial up my ISP through PPPoE. In the past, I get it working successfully with another PPPoE provider, but I changed it to another ISP that requires a specific VLAN to DSL through PPPoE successfully.
    It uses Fiber so I bought a GPON (Huawei EG8010H) to convert Fiber to Ethernet and connect it to AP-203R eth0 port and set up the PPPoE credentials at Configuration page of Instant AP, but it fails. I checked the GPON authentication at my GPON and it's password is correct, but my GPN do not allow set up a specific VLAN and I believe that I could not found a way to set up it at AP-203R neither. My ISP provider requires the Internet traffic to go through VLAN ID 600. I already tried to set up "Uplink switch VLAN" (enet-vlan) to VLAN ID 600 and set up it as a Admin UP and Native VLAN at "Wired Profile", but it still do not work. I believe it's not working because for some reason the Instant AP isn't tagging the traffic with VLAN ID 600, because if I set up my ISP router to Bridge mode (it has a Fiber port, so it has a built-in ONU) with VLAN 600 tagged and set up the PPPoE credentials from my ISP provider, it works just fine. It fails only when I use an external GPON.
    If I try to use my external GPON and my Linux machine to connect through DSL PPPoE it fails too, even when I spoof the ISP router mac-address, but it also works just fine with my ISP router in bridge mode (instead of using my external GPON) when I DSL PPPoE through my Linux machine.
    I noticed that every reboot it changes the "pppoe-password" hash every time the AP restart, but it doesn't seems to be an issue because it changes even when using my ISP router at bridge mode and it works just fine.
    So I would like to know if it's possible to tag VLAN traffic at eth0 port. There's seems that TP-Link, ASUS and other home providers allows to setup a VLAN ID to Internet, Telephone (VoIP) and IPTV traffic, as most providers seems to offer those features through Fiber instead of Sattelite (TV) and ADSL/RJ-11 (Telephone). So it seems to be a great feature to be added at PPPoE mode at Aruba Instant AP and Aruba Instant On product line, so it could possibly replace the ISP router using a ONU.
    A thing that I am willing to test into the future is to buy another GPON that offers VLAN tagging and Bridge mode if Instant AP do not allow VLAN tagging to PPPoE, so I could replace my ISP router using less Power (Watt) in comparision to my ISP router, and less space too.
    Sorry for my bad english. English isn't my native language.
    Here's the config that I tried to setup the eth0 to VLAN ID 600, but it fails to connect not PPPoE server (show pppoe status). The pppd debug log (show pppoe debug-log) seems to return empty even when I enable IAP debug logs.
    20:4c:03:1a:fd:8c# show running-config
    version 8.9.0.0-8.9.0
    virtual-controller-country BR
    virtual-controller-key 008d4f0401adb6436e944042aff47409cd5ee2feb8cc8b08ee
    name SetMeUp-1A:FD:8C
    terminal-access
    clock timezone none 00 00
    rf-band all
    allow-new-aps
    allowed-ap 20:4c:03:1a:fd:8c
    arm
    wide-bands 24ghz,5ghz
    80mhz-support
    min-tx-power 12
    max-tx-power 127
    band-steering-mode prefer-higher-band
    air-time-fairness-mode default-access
    channel-quality-aware-arm-disable
    client-aware
    scanning
    client-match
    rf dot11g-radio-profile
    max-distance 0
    max-tx-power 9
    min-tx-power 6
    disable-arm-wids-functions off
    free-channel-index 40
    rf dot11a-radio-profile
    max-distance 0
    max-tx-power 18
    min-tx-power 12
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    web-server
    ssl-protocol tlsv1_2
    hash-mgmt-password
    hash-mgmt-user admin password hash 085a42f902590c789904ac2d639e6fa0dbc53ac183fc1 247227d7371206685b46303f63328
    wlan access-rule default_wired_port_profile
    index 0
    rule any any match any any any permit
    wlan access-rule wired-SetMeUp
    index 1
    rule masterip 0.0.0.0 match tcp 80 80 permit
    rule masterip 0.0.0.0 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule HOMEOLIVEIRA
    index 2
    wlan ssid-profile HOMEOLIVEIRA
    enable
    index 0
    type employee
    essid HOMEOLIVEIRA
    wpa-passphrase 8443743fc1848ba609a17d5d53f64a984a79d6c2da2faf19
    opmode wpa2-psk-aes
    max-authentication-failures 0
    vlan guest
    rf-band all
    captive-portal disable
    dtim-period 1
    broadcast-filter arp
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    enet-vlan 600
    auth-survivability cache-time-out 24
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    wired-port-profile wired-SetMeUp
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-SetMeUp
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 600
    no shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    auth-server InternalServer
    no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    pppoe-uplink-profile
    pppoe-username cliente@cliente
    pppoe-passwd 498241d46d7800940651d78e4a339875
    airgroup
    disable
    airgroupservice airplay
    disable
    airgroupservice airprint
    disable
    cluster-security
    allow-low-assurance-devices
    Here's the config that is working at Bridge mode:
    virtual-controller-key f4f742b801f46824b50b250a6d5a7a024b68dd1ee9a4c50a10
    terminal-access
    rf-band all
    allow-new-aps
    arm
    80mhz-support
    min-tx-power 15
    max-tx-power 127
    client-aware
    scanning
    max-distance 0
    max-tx-power 9
    min-tx-power 6
    max-distance 0
    max-tx-power 18
    min-tx-power 12
    extended-ssid
    web-server
    hash-mgmt-password
    hash-mgmt-user admin password hash f064423f0262b5d11cc1fe0a84855f55ce137f21972a91a509cd9eafed398f3eed359c2bf2
    index 0
    index 1
    index 2
    enable
    index 0
    type employee
    essid HOMEOLIVEIRA
    wpa-passphrase eb6be60185db83d0605bd65112f466f602376390b69375ae
    opmode wpa2-psk-aes
    vlan guest
    rf-band all
    dtim-period 1
    server localhost
    port 80
    url "/"
    https
    blacklist-time 3600
    ids
    allowed-vlan all
    native-vlan guest
    no shutdown
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    allowed-vlan all
    native-vlan 1
    shutdown
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    uplink
    preemption
    enforce none
    pppoe-passwd fe343b7bb4c45c7ebf4ca722258b4834
    airgroup
    disable
    disable
    disable
    cluster-security
  • 2.  RE: IAP PPPoE VLAN
    Posted Aug 04, 2022 08:30 PM
    you can tag the mgmt VLAN of the Aruba Instant in this way.
    Ensure that Virtual Controller VLAN is not the same as native VLAN of the IAP.
