  • 1.  IAP queries
    Posted Oct 07, 2015 01:01 AM
    We are planning to deploy IAP 103- 7qty. Please help with below queries:-
    1) How many users can we create in internal database.
    2) We are using unmanagable switch, will this be a problem for IAP's to form a cluster.
    3) If there is some coverage hole, can i extend the signal using a repeater.
    Thanks.
  • 2.  RE: IAP queries
    Posted Oct 07, 2015 05:49 AM
    Hi Mohan,
    IAP internal user DB will support upto 512 users Please make a note, IAP-9x supports only 256 user entries. If there are already 512 users, IAP-9x will not be able to join the cluster
    To form a cluster IAPs should be in the same broadcast domain hence it doesn't matter whether it is a manageable switch or unmanageable switch.
    Coverage holes all depends on your deployment . don't forget you have IAP mesh point option available.
    Please feel free for any further help on this.
  • 3.  RE: IAP queries
    Posted Oct 07, 2015 07:55 AM
    Hi Venu....thanks for your reply....we will be using wpa2/presahred key as authenticaiton. Currently we will not deploy IAP's in mesh mode...please confirm if we can use repeaters...
  • 4.  RE: IAP queries
    Posted Oct 08, 2015 01:19 PM
    HI Mohan,
    Yes we can connect an IAP to a third party bridge by configuring WiFi uplink.
  • 5.  RE: IAP queries
    Posted Oct 09, 2015 01:16 AM
    Thanks for your help Dhanraj...
