IAP (RAP Mode) - Split Tunnel Problem
  • 1.  IAP (RAP Mode) - Split Tunnel Problem
    Posted May 07, 2018 12:28 AM
    I have an iap315 provisioned as rap to a 7005 controller.
    I have two SSID's in that Rap Ap group.
    When I set in split-tunnel fordwarding mode the web and app are not blocked/filtered.
    Is the app/web filter/block possible in split-tunnel mode?
     How can i achive that?
    grettings!
  • 2.  RE: IAP (RAP Mode) - Split Tunnel Problem
    Posted May 08, 2018 07:19 AM
    App and Web classification is done at the controller, so if the traffic hits the controller (tunneled, action:permit) it should work. If the traffic is switched locally (route-nat), it is not expected to work.
  • 3.  RE: IAP (RAP Mode) - Split Tunnel Problem
    Posted May 08, 2018 12:51 PM
    Ok. Thank you.
