last person joined: 7 hours ago
IAP remote config.
  • 1.  IAP remote config.
    Posted May 01, 2020 04:49 PM
    Now that I know how to convert a RAP into IAP remotely via the controller. I would like to see if they are any tips on how to convert the IAP into IAP-VPN and build a tunnel with a controller.
    I do have an Airwave server setting on the corp network with private IP. I said private IP because if it was public, I can use Aruba activate, push the config to IAP and build a tunnel to the controller.
    Thanks!
  • 2.  RE: IAP remote config.
    Posted May 01, 2020 07:18 PM
    There is no conversion needed for IAP to IAP-VPN.
    you need to configure it. here is the recent guide.
    https://asp.arubanetworks.com/downloads/documents/RmlsZTpjODVhZGMxZS02ZDY1LTExZWEtODU3My0xZmFkODFjYjlmNjM%3D
  • 3.  RE: IAP remote config.
    Posted May 04, 2020 10:42 AM
    I appreciate the link, very informative. I am not using Aruba Central, I have airwave--> controllers-->IAP as my setup. any ideas how implement IAP-VPN remotely with this setup?
  • 4.  RE: IAP remote config.
    Posted May 04, 2020 12:09 PM
    I recommend you check this video that explains IAP-VPN configuration in detail.. If Airwave is used for management of IAPs, then configuration can be done from Airwave but the logic is the same..
    https://community.arubanetworks.com/t5/Video/IAP-VPN-DHCP-Options-Explained-Webinar/ta-p/647027
  • 5.  RE: IAP remote config.
    Posted May 04, 2020 01:19 PM
    I saw that video before. I probably missed something.  I will revisit and check back again.
    Thanks, Ayman!
