IAP securelogin.arubanetworks.com redirect question
  • 1.  IAP securelogin.arubanetworks.com redirect question
    Posted Sep 14, 2017 10:53 AM
    Hi guys, this is my first time here so I hope I follow the rules correctly...
    I have a question regarding my setup of an IAP 325 with Clearpass captive portal. I have been able to make this work perfectly when the Virtual Controller manages the IPs for the clients so I know the Clearpass guest registration portal and services are working correctly. I do not want the IAP to be accessable from the guest network so I set the client IP to be network assigned and in a separate VLAN to what the IAP is in. This is causing a problem when the client autheticates (the clients can reach the Clearpass webpages to register/login) and the webpage redirects to securelogin.arubanetworks.com as that address resolves to an IP on the IAP that the clients can no longer reach.
    How do I get around this problem? There must be a way of keeping the IAP in a separate management VLAN to the clients but how do I do that if part of the authentication is to communicate withthe IAP again?
    Gerry
