IAP simple splash page setup for quest network
  • 1.  IAP simple splash page setup for quest network
    Posted May 02, 2016 05:43 AM
    We have a WIFI based on IAP 205
    We need to make a very simple setup for a guest network with the following requirements:
    - Guest connects to SSID "XX Guest"
    - Splash page is automatically shown.
    - Splash page is an external website, with a email subscription form. There are external references on the website, such as webfonts, submission page etc, that shoould all work.
    - Guest is not required to submit the form, but should have unlimited access from the start.
    I have been trying to set this up using:
    - Spash page type: External
    - Captive portal: Authentication Text
    - IP and URL for the splash page
    - Captive Portal Failure: Allow internet
    - Auth text: velkommen (random text from the website)
    - Auth Server: None
    With these setting the splash page either does not open at all, or sometimes open an adress called "http://www.msn.com/da-dk/?ocid=wispr".
    Where can I find documentation as for how to set up IAP for this purpose?
  • 2.  RE: IAP simple splash page setup for quest network
    Posted May 02, 2016 01:59 PM
    while i look further for you, can you check hosting the attached pages instead of your own page on the external web server?
    the instructions on using these pages with a controller in data center are attached. You can take a cue from that on how to use the pages.
    I understand you need just an email ack, and i am checking on page format that can work for it.
  • 3.  RE: IAP simple splash page setup for quest network
    Posted May 03, 2016 08:18 AM
    I will try your files and get back to you.
    A lot of the descriptions include a controller, is that required?
  • 4.  RE: IAP simple splash page setup for quest network
    Posted May 03, 2016 08:20 AM
    Just one comment, actually no acknowledgement is needed. The guest can choose to enter their email or simply just leave the splash page and should still be online after this.
  • 5.  RE: IAP simple splash page setup for quest network
    Posted Nov 01, 2016 10:08 AM
    We have set up a simple splash page on iap-205.
    It has been set up with an external portal hosted on a http site.
    For smartphones (iphone, Android etc) the captive portal pops up correctly upon connecting to the SSID, and the login form also works.
    When connecting from a Windows 10 computer no pop ups come up automatically and when opening any browser, Chrome or IE give a failure. Only by manually typing a non-https address the captive portal comes up.
    Is the any way to force trigger the Captive Portal detection in these browsers?
  • 6.  RE: IAP simple splash page setup for quest network
    Posted Nov 01, 2016 01:38 PM
    Check this:
    http://blog.superuser.com/2011/05/16/windows-7-network-awareness/
    & you can set http as home page of the browser.
  • 7.  RE: IAP simple splash page setup for quest network
    Posted Nov 04, 2016 06:29 AM
    Thanks, I got it to work on Windows computers by deleting msftncsi.com from the whitelist (other posts I have found said that it HAD to be whitelisted in order to detect captive portal, but that turned out not to be the case.). It is a guest network, so it is not possible to prepare the devices with non-http start pages.
    Another problem has emerged though.
    The Reauth interval is set to 546 hours, but after 15-20 minutes the guests lose connection and get the captive portal again. How can I set the controller to "remember" the clients for a certain amount of time?
    Users are initially granted access by submitting a form with the following code:
    <form method=POST action="http://securelogin.arubanetworks.com/cgi-bin/login">
    <span class="bodytext">
    <input id="user" name="user" value="guest" type="hidden" accesskey="u" /><br>
    <input id="password" name="password" value="wRcre3eQhgc" type="hidden" accesskey="p" />
    <input name=cmd value="authenticate" type="hidden">
    <input name=mac value="" type="hidden">
    <input name=ip value="" type="hidden">
    <input name=essid value="" type="hidden">
    <input name=url value="http://www.arubanetworks.com" type="hidden">
    <input type="submit" name="Login" value="Login" class="button" onclick="redirect()" />
    <script>
    function redirect()
    window.location='www.zxzxzxzxzx.com';
    </script>
    </span>
    </form>
  • 8.  RE: IAP simple splash page setup for quest network
    Posted Nov 07, 2016 11:54 AM
    kindly share a show tech, i want to take a look at how you have set the timer you are referring to.
  • 9.  RE: IAP simple splash page setup for quest network
    Posted Nov 08, 2016 03:27 AM
    Hi, it is attached to to my last post, reauth interval is set to max.
    Should I change Inactivity time out under the WLAN settings for the ssid as well?
  • 10.  RE: IAP simple splash page setup for quest network
    Posted Nov 08, 2016 07:33 AM
    Can you  change inactivity timer and try again please.
  • 11.  RE: IAP simple splash page setup for quest network
    Posted Nov 28, 2016 04:33 AM
    Changing the Inactivity time seems to have helped, guests are not thrown off so often anymore.
    Another problem has emerged though, a lot of guests have problems logging in with a normal Windows laptop.
    I suspect that security software and settings can be a factor here, since the connection is unencrypted. Is there any way to make the connection encprypted when using a simple external portal? The login page is based on the code mentioned above.
    I would be happy to hear about alternative recommendations for a captive portal solution.
    The captive portal's one purpose is to log the guest's email address and to have dem answer 2 questions before getting access.
  • 12.  RE: IAP simple splash page setup for quest network
    Posted Nov 28, 2016 07:43 AM
    So your question is can using IAP, splash page be hosted on external server and accessed via http and not https. correct?
