IAP SSID Auth Server randomly reverts to Internal
  • 1.  IAP SSID Auth Server randomly reverts to Internal
    Posted Aug 01, 2018 12:10 PM
    Lately we have been noticed that sometimes after we make a change to anything related to an SSID on an IAP the Auth server for that SSID will revert from a RADIUS server to Internal Server.
    For example for our Guest SSID i was changing our captive portal address to host name instead of IP and changing the port from 80 to 443. When i hit finished the Auth Server1 server was changed to Internal.
    So far it has happened on 115s and 205s running 6.5.4.2.  Before i call TAC and they obligitory tell me to upgrade the firmware.  I wanted to see if anyone else has seen this before.
  • 2.  RE: IAP SSID Auth Server randomly reverts to Internal
    Posted Aug 06, 2018 08:26 AM
    funny enough I have seen the same thing on my IAP-315 version 6.5.4.x code. I thought I was losing my mind...
