I have an IAP 115 which i configured for an employee network with all basic settings but it does show the SSID instant and does not broadcast the newly added SSID to the clients.
SSID is shown in the GUI but not shown or detected by clients. However i have configured all things in the simplest possible way as shown in the documents.
Thanks for your reply.
Farooq.
Thanks for all your replies,
The problem solved with software upgrade.
Regards.
I have reset to factory a number of times , i can login through console and through GUI (ethernet port) but can not login through wifii or can not use it as a user.
