IAP Static Host entry?
  • 1.  IAP Static Host entry?
    Posted Jul 13, 2015 10:38 AM
    I'm trying to get my guest network users to use public DNS servers (Google...), but be able to get to my CPPM server via the FQDN for authentication. I don't want to use my internal DNS servers.
    Is there a way to add a static host entry for the guest network? I don't want to use an IP because of the cert error.
    The only other option I can think of is to build another DNS server to handle these requests.
  • 2.  RE: IAP Static Host entry?
    Posted Jul 13, 2015 11:14 AM
    You would need to rely on an upstream routers DNS proxy capability.
    Tim
  • 3.  RE: IAP Static Host entry?
    Posted Jul 27, 2015 10:30 AM
    maybe a Destination NAT on the pre-auth role for the Guest network.
  • 4.  RE: IAP Static Host entry?
    Posted Jul 27, 2015 10:33 AM
     We actually using PA-200/500's upstream of these, and they have DNS-Proxy built-in. Managed to get it working that way, will also let me do some other things down the line.
