IAP support with Aruba central
  • 1.  IAP support with Aruba central
    Posted Mar 08, 2017 08:23 PM
    When you got 10 APS with Aruba central
    And you decided just to pay for the subcription but not the Aruba care of those 10 IAPS
    You will still get TAC support with Aruba central subcription for those 10 IAPS
    The only difference is that you wont have advance hardware replacement on those IAPS right? but you will still get TAC support?
    Im pretty sure is like this but im just checking on this.
    Cheers
    Carlos
  • 2.  RE: IAP support with Aruba central
    Posted Mar 30, 2018 07:53 AM
    LIttle bit late, but correct
