iAP Templates using custom variables
  • 1.  iAP Templates using custom variables
    Posted Jan 16, 2013 12:26 PM
    This is a really cool addtion to the process - Thanks!
    I get using %if custom = such and such%, but what I find is that I'd rather do more interesting logic.
    Is there a NOT operator?
    I've tried !=, <>, and NOT to no avail.
    --Matthew
  • 2.  RE: iAP Templates using custom variables
    Posted Jan 16, 2013 02:43 PM
    Glad you like the feature.  This is the kind of feedback that really helps improve the product.  We currently do not have a 'NOT' operator, but please file it into the Ideas Portal on the support site.  Can you also provide some use cases?
  • 3.  RE: iAP Templates using custom variables
    Posted Jan 16, 2013 03:31 PM
    We are replacing an existing (bad) WLAN product, but don't want to have both hot at the same time on the same SSID.
    I want use custom_variable_2 to indicate variation from normal -- my preference is "Install" and blank.
    So what I'm actually looking for is a test for blankness.
    %if %custom_variable_2%=Install%
    set dummy SSID
    put radios in spectrum monitor mode
    etc.
    %endif%
    %if custom_variable_2%NOT=Install%
    do normal stuff
    %endif%
    I'm finding out that the synatx I'm using above isn't actually working.  Is it possible to test the variable for a specific string, or is it just a test of filled or not filled?
    --Matthew
  • 4.  RE: iAP Templates using custom variables
    Posted Jan 16, 2013 05:52 PM
    Templates only test the existence or not of a variable on the device's variable listing.  It's not testing the content of the variables.
  • 5.  RE: iAP Templates using custom variables
    Posted Jan 16, 2013 06:07 PM
    Then I think I'll just head on over to the feature request page...
  • 6.  RE: iAP Templates using custom variables
    Posted Nov 14, 2014 07:08 AM
    Hi msabin.
    Did you ever get this to work, either with a feature upgrade or a workaround?
    Is it possible to check if a field is NULL?
    what i am trying to achieve is setting bandwidth limits as per a custom_variable
    I have got the following:
     %if custom_variable_1%
     bandwidth-limit %custom_variable_1%
     %endif%
    bandwidth-limit 2048
    This appears to work, but has the side effect of causing an error in the config
    Apologies for resurrecting an old post
    TIA
    G
  • 7.  RE: iAP Templates using custom variables
    Posted Nov 17, 2014 02:15 PM
    I use that syntax for 7 or 8 variables now, all seem to work fine and I don't have any errors in the config reported.
    The answer was that %if custom_variable_1% is essentially testing for NULL and if NULL then the if returns negative and the line is skipped.
    What version of iAP/Airwave are you on, and what error are you getting.
  • 8.  RE: iAP Templates using custom variables
    Posted Nov 18, 2014 03:24 AM
    Hi Matthew,
    We are on AMP 7.7.13 and iAP 6.4.2.0.
    When looking at the config, it shows the 2 bandwidth lines as such
    Desired   bandwidth-limit 2048
              bandwidth-limit 768
    Looking at the VC and the line shows
    Configuration:    Error (Configuration contains invalid commands)
    running a repair doesnt seem to resolve the issue.  I am 99.999% sure its not anything else in the config as if i remove the logic and revert back to
     %endif%
    The error doesnt appear, making me think that the rest of the config is OK, and its this bit causing the issue.
     TIA
    G
  • 9.  RE: iAP Templates using custom variables
    Posted Nov 18, 2014 03:14 PM
    Yeah, I ran into the same behavior.
    My solution was to dedicate a variable to that valueand set it for all locations.
    We enter the "default" or "normal" value at all sites, then change it for those which need a variation.
  • 10.  RE: iAP Templates using custom variables
    Posted Nov 19, 2014 03:58 AM
    Hi Matthew,
    Glad its not just me :)
    What method did you use to set all of them as a "default"?
    Did you use the template to set the default limit then manually change the ones that required a different limit?
    TIA
    G
  • 11.  RE: iAP Templates using custom variables
    Posted Nov 19, 2014 07:42 PM
    Using the word "default" may have been misleading.
    I think your conclusion is what I'm doing:
    I use the variable to set the value for all sites. Enter the normal value when you set up a site, them edit it as you discover a need to make the change.
  • 12.  RE: iAP Templates using custom variables
    Posted Nov 21, 2014 03:54 AM
    spot on, thank you
