IAP TLS authentication
  • 1.  IAP TLS authentication
    Posted Oct 25, 2012 03:53 PM
    Greetings,
    Hate to be a total newbie but here it goes.  I am trying to setup a TLS authenticated SSID on IAP-135 running 6.1.3.4-3.1.0.0_35320.  Any help on this would be much appreciated.  I've read the documentation in the UG but not really getting a clear understanding of all the moving parts from that.
    MJT
  • 2.  RE: IAP TLS authentication
    Posted Oct 25, 2012 11:04 PM
    Not trying to oversimplify things, but the "authenticator", which would be the controller or IAP in this case, just forwards radius traffic to the radius server.  At most, you have to just configure WPA2-AES encrytion, the Network and the Radius Server.  All the rest of the configuration occurs on the Client and the Radius Server for TLS.
    info on how to setup EAP-TLS can be found in the thread here:  http://community.arubanetworks.com/t5/Authentication-and-Access/EAP-TLS-configuration/m-p/37358/highlight/true#M729
    Definitely NOT simple or straightforward.
