iap to cap or rap
  • 1.  iap to cap or rap
    Posted Jan 29, 2013 07:27 AM
    Hi
    i have 3 IAP:s running 6.1.3.4-3.1.0.0 and im trying to convert them to either a cap or a rap. My controller is running 6.1.4.1 so there should not be any problem trying to convert them but still i cant. Theres no firewall rule blocking the comunication and im sitting in the same LAN as the controller so i have direct communication to it.
    what could possibly wrong?
  • 2.  RE: iap to cap or rap
    Posted Jan 29, 2013 02:40 PM
    I've converted a few iAP93 to cAP with no hitch.
    Could you provide a few more details?
    Model of iAP, what actually happens when you try etc.
  • 3.  RE: iap to cap or rap
    Posted Jan 30, 2013 10:10 AM
    it was a firewall rule after all that blocked it.
    thanks for the input
