IAP to Controler GRE Tunnel
  • 1.  IAP to Controler GRE Tunnel
    Posted Sep 27, 2013 05:58 AM
    Hello, is there a Document available with the necessary configuration Steps for both Sites to build a GRE Tunnel between the Controller and the IAP?
    Thank you and best Regards
  • 2.  RE: IAP to Controler GRE Tunnel
    Posted Sep 27, 2013 06:33 AM
    The suetup is outlined in the guide.  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Default.aspx?EntryId=8868
    One thing to note is that the APs and Controller must NOT be on the same subnet.
  • 3.  RE: IAP to Controler GRE Tunnel
    Posted Sep 27, 2013 07:36 AM
    Hello, yes on the IAP Docs it is written what to Configure on IAP Site. What is necessary to configure on Controller?
  • 4.  RE: IAP to Controler GRE Tunnel
    Posted Sep 27, 2013 07:57 AM
    got it.  you just need to create the tunnel on the controller and point to the IAP that is hosting the VC.  It won't work if it points to the VC address, or at least it didn't when I tried.
    On the controller,
    interface tunnel 1
    description "IAP tunnel"
    tunnel source <controller ip>
    tunnel destination <IAP ip>
    tunnel vlan <x>
    trusted
  • 5.  RE: IAP to Controler GRE Tunnel
    Posted Oct 09, 2013 12:25 AM
    the above link no longer works, can you please provide a working link?
  • 6.  RE: IAP to Controler GRE Tunnel
    Posted Oct 09, 2013 08:30 AM
    That link is valid even without a login to the support site, but try navigating to http://support.arubanetworks.com/HOME/tabid/37/Default.aspx select 'Documentation' then 'Software User and Reference Guides' select 'Aruba Instant' and pull the guide down for the current 3.4 release of IAP code.
