IAP UCC to AirWave
This thread has been viewed 32 times
  • 1.  IAP UCC to AirWave
    Posted Jan 07, 2021 03:56 PM
    Is there any way to get UCC data from IAP's using latest AOS to AirWave?
    Thanks!
    Thanks!
    Ola Marvik
    Network Engineer, GES EMEA
  • 2.  RE: IAP UCC to AirWave
    Posted Dec 09, 2021 11:38 AM
    I am also interested to do that. Anyone knows how to do or if it is not possible?
    Thanks.
    BDE
    Blaise Delaville
  • 3.  RE: IAP UCC to AirWave
    Posted Dec 09, 2021 04:45 PM
    AFAIK Instant AP's UCC monitoring statistics are only available on Aruba Central not Airwave.
    Even though Airwave has a UCC dash, it is only for Controller based deployments.
  • 4.  RE: IAP UCC to AirWave
    Posted Jan 31, 2024 11:45 AM
    even if the IAP is managed by AirWave isn't possible to get UCC data from IAP?
    For IDS instead?
    CB3
