IAP use Controllers Captive Portal
  • 1.  IAP use Controllers Captive Portal
    Posted Oct 13, 2014 06:06 AM
    I want to deploy Instant APs with guest Portal.
    Is it possible to deploy a IAP and use the controllers captive portal?
    What I need is the url of the controllers captive portal web page so I can put it into the IAP.
    Does this work?
  • 2.  RE: IAP use Controllers Captive Portal
  • 3.  RE: IAP use Controllers Captive Portal
    Posted Oct 13, 2014 09:02 AM
    no, I want do use Instant with the controllers captive portal.
    Not Clearpass with social login ...
    thanks
  • 4.  RE: IAP use Controllers Captive Portal
