IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
  • 1.  IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    MVP GURU
    Posted May 09, 2014 11:03 AM
    When there is same problem with Wireless Network, it is sometime needed to have same pcap trace for troubleshooting !
    With new 802.11ac standard, there is no yet airpcap available for make pcap trace !
    But with Aruba IAP, it is possible to use IAP for remote pcap ! with Wireshark (it is also possible with Aruba Controller !)
    You need :
    • a IAP (recommanded IAP225, if you when sniffing 802.11ac)
    • a computer with Wireshark (> 1.11.3 !) available here
    Connect to the IAP with SSH :
    It is the same login and password like web administration page
    Search the BSSID for access point using show ap monitor status command.
    in WLAN Interface, there is the list of BSSID (one for 80211b/g and one for 80211/a/n/ac)
    In my example, the BSSID is 24:de:c6:8b:12:20
    Now use pcap command !
    There is multiple argument in command
    pcap start BSSID @IPofcomputer UDPPort format size
    • BSSID is the BSSID for IAP
    • @IPofcomputer is the address IP of computer with Wireshark
    • UDPPort is the UDP Port where the packet is send to the computer (use 5555)
    • format is the format of packet send to the computer (there is pcap, peek, airmagnet, pcap radio or ppi, see after for recommended value)
    • size the max size of packet (use 5000)
    About format, actually airmagnet format is not yet support by Wireshark, it is recommended to use pcap for simple remote, if you need radio info use PPI or pcap radio format
    The packet capture is start with id 5
    Now launch Wireshark and go to the preference
    Search Aruba ERM preferences
    Set the UDP port configured in IAP (5555) and select also the format of captured packets (in my example, pcap (type 0))
    and launch capture on your computer
    You should be received all traffic from your network card, it is possible to filter the IAP traffic with following display fitler : udp.port==5555
    You can now troubleshooting your wireless network :smileyvery-happy:
    To display the list of pcap remote, you can use the following command :
    show pcap status
    for stop the capture, in SSH terminal, use the command :
    pcap stop BSSID ID
    Replace BSSID by the BSSID of IAP and ID by the id number of pcap capture (use show pcap status to found this number)
    :smileyhappy:
  • 2.  RE: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    Posted May 09, 2014 11:25 AM
    This looks promising but I'm not very familiar with IAP configuration, do you need to configure the IAP a specific way and how are you connected to the IAP?
  • 3.  RE: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    MVP GURU
    Posted May 09, 2014 11:27 AM
    Hi rosie
    No specify configuration of IAP and my IAP is connected on my network... :-)
  • 4.  RE: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    Posted May 09, 2014 11:38 AM
    I'm assuming this can only be done if you are local to the location and not remote.
  • 5.  RE: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    MVP GURU
    Posted May 09, 2014 11:45 AM
    Yes... but the capture is no in your computer ;-) (and it is possible to route the packet in your network !)
  • 6.  RE: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    Posted May 09, 2014 11:44 AM
    I remember reading a post shared previously where the laptop was directly connected to the IAP running a specific code.
    Here is the previous post: http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/AP-225-Sniffer/td-p/142005
  • 7.  RE: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    Posted May 09, 2014 05:05 PM
    Great article! You helped solve an immediate need I had.
  • 8.  RE: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    Posted Jun 04, 2014 02:11 AM
    Lately I'm finding that when doing a capture from the controller port 5555 is denied in the datapath session table.  If you change the port to something like 162, it will get through to the wireshark client.
  • 9.  RE: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    MVP GURU
    Posted Jun 04, 2014 10:55 AM
    Strange,
    No Uplink ACL on AP ? it is Campus or RAP ?
  • 10.  RE: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    Posted Jun 04, 2014 11:11 AM
    no uplink ACL.  It was a campus AP on 6.3.x
    I saw on another post to use one of the standard ports (like 162) to 'trick' the controller into allowing it.
    I did put this command in as well,
    ap packet-capture open-port 5555
     but made no difference.  That gets added to the sys-ap-acl and my aps are using the ap-acl which I guess is why it got denied.
    In any case, it was my lab controller, so maybe things got messed up with so many changes and upgrades/downgrades.  Main thing is I got it to work in the end.
    :smileyhappy:
  • 11.  RE: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    Posted Jul 15, 2014 02:29 PM
    Doesn't work for me. Tried both Wireshark 1.12 and Omnipeek 8, all possible ports and formats, just doesn't work.
    My setup: 3G modem port 1-> IAP103(6.4.0.2-4.1.0.0_44004)->wifi clients
                      3G modem port 2 ->Laptop with Capture client
    the IAP and the Capturing Laptop are on the same subnet, they can ping each other.
    Any clues ?
  • 12.  RE: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    Posted Jul 15, 2014 10:57 PM
    Please copy/paste the commands you're using.
  • 13.  RE: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
    Posted Jul 16, 2014 09:14 AM
    On the IAP:
    pcap start d8:c7:c8:c4:4d:a0 172.16.1.3 5555 0 5000
    pcap start d8:c7:c8:c4:4d:b0 172.16.1.3 5555 0 5000
    Wireshark:
    Aruba_ERM: 5555, pcap(0)
    then filter with udp.port==5555. Nothing comes in.
    If I remove the filter udp.port==5555, then I can see some Fragmented IP packets from 172.16.1.2(IAP) to 172.16.1.3(Wireshark pc).
