IAP VC Management
  • 1.  IAP VC Management
    Posted Mar 07, 2014 10:50 PM
    Is it possible to access the VC from a guest SSID?  I am looking to just enable this temporarly for a meeting.
  • 2.  RE: IAP VC Management
    Posted Mar 08, 2014 07:02 AM
    Yes, you can. You can put a network based firewall on the SSID to prevent anyone from accessing it.
  • 3.  RE: IAP VC Management
    Posted Mar 10, 2014 04:59 AM
    If you check the IP setting details of your Guest client (ipconfig), you can obtain its IP Default Gateway. Go trougth the web to this IP and you have access on your VC. The access to the VC is always enabled by default for Guest Network.
    Massimo
    [If you found my post helpful, please give kudos]
