Aruba Central
This thread has been viewed 22 times
  • 1.  IAP VC mode
    Posted Feb 21, 2022 02:04 PM
    How can I disable/remove the VC on the IAPs? Forcing me to have this feature and not giving users ability to disable this feature does not make sense. When APs join Central under the default group all of them end up joining the VC. Is there a way to prevent that?
    I saw this post and was hoping there is a solution by now:
    https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=14577
  • 2.  RE: IAP VC mode
    MVP GURU
    Posted Feb 21, 2022 02:23 PM
    At least one of the APs in the cluster needs to be running as a VC. It is not until AOS10 that the APs act independently in central.
    If an AP boots up on the same L2 segment as the VC, it will join unless auto-join has been turned off in the system settings.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: IAP VC mode
    Posted Feb 21, 2022 06:19 PM
    Thank you so much, that explains the behavior.
    Mohammad Ali
