IAP VC not reachable after some time
  • 1.  IAP VC not reachable after some time
    Posted Jun 24, 2020 05:56 AM
    Hi all,
    I have a strange problem.
    I have a cluster of AP 305 (ursa) and 315 (Hercules) on the same subnet on a virtual controller.
    When I restart the APs, I can reach the VC with the ip but after sometimes, I can't. I't like the VC is not on this IP. But I can still reach the APs via their IP.
    The AP are on version 8.6.0.4_74969.
    Can somebody help to solve this problem ?
  • 2.  RE: IAP VC not reachable after some time
    MVP EXPERT
    Posted Jun 24, 2020 06:35 AM
    When this occurs, do you have an ARP entry for the VC IP address?
  • 3.  RE: IAP VC not reachable after some time
    Posted Jun 24, 2020 06:41 AM
    No. I don't have any arp entry for VC anymore (on the gateway router).
  • 4.  RE: IAP VC not reachable after some time
    Posted Aug 31, 2020 01:10 PM
    My problem is not resolved.
    I remove all the ap, factory reset some aps. The problem is still there.
    I'm in aruba instant 8.0.5.
    I can ping the ip of iap from the master ap but not from the gateway.
  • 5.  RE: IAP VC not reachable after some time
    Posted Aug 31, 2020 03:33 PM
    Does the gateway have the mac address of the VC in the ARP table?
    Nevermind.  Maybe someone else can help.
