iap virtual controller as dhcp sever
  • 1.  iap virtual controller as dhcp sever
    Posted Mar 11, 2014 02:26 PM
    I am using iap & configuring in my iap virtual controller as DHCP server.I am creating some 3 ssid. I this senario users connecting to the differerent ssid can they get different range of ip adress
  • 2.  RE: iap virtual controller as dhcp sever
    Posted Mar 11, 2014 02:56 PM
    Hello Mjnayak
    I beliaeve you can
    Go on the tabs you go up in your virtual controller go to more-> go to DHCP  click on it
    On local dhcp Scopes
    In there click new and put the DHCP scope and all the information in there but you put a random vlan let say you put vlan 100
    When you done  go and create a new SSID
    When you are in here
    Put vlan network assign and put vlan 100 in there and i bealive it should work.
    I do this to assign local ip address when im doing vpn termination from a instant ap to the Controller but it should work i bealive for this situation.
    Try that
    Cheers
    Carlos
  • 3.  RE: iap virtual controller as dhcp sever
    Posted Mar 11, 2014 03:28 PM
    In addition, you need to tag/trunk the configured VLAN IDs from each IAP in the cluster.  The master IAP is both the DHCP server and gateway for all clients in this mode.
