This has been partially answered in some posts, but I am wondering if the Instant VC can be used as a DHCP server for devices other than the wireless clients that are connecting to the SSIDs hosted on the IAP.
It kind of does. Basically what I was looking for is setting up some switches to use the IAP as the DHCP server, but it sounds like that will not work.
Thank you for your reply.
So I need to set my switch ports to trunks? I am using HP 1920 switches. This is a very small install so no need/budget for larger switches.
