IAP Vlans ID Mismatch
  • 1.  IAP Vlans ID Mismatch
    Posted Sep 11, 2016 04:26 PM
    I have an IAP-325, firmware 6.4.2.6-4.1.3.0, configured to serve two SSIDs. The IAP is connected to a trunk port on a Cisco SG500 switch and there are 2 employees Vlans configured.
    Cisco side we have a port for the up link to the IAP configured as:
    switch port mode trunk, native Vlan = 1, Vlans allowed 1 Untagged, 2-3 Tagged.
    The switch provides two DHCP pools 192.168.1.x and 192.168.2.x to serve the Vlans.
    IAP has a static IP address assigned on the net 192.168.0.x (native Vlan 1 used for management purpose).
    I have setup 2 SSIDs:
    SSID Office, Client IP assignment - Network  assigned, Client Vlan management Static 2
    SSID Sales, Client IP assignment - Network assigned, Client Vlan management Static 3
    When i try to connect to the SSID Office (serving Vlan 2) it goes on DHCP timeout and the defualt DHCP address 169.254.x.x is provided (so not working), whilst when i connect to the SSID Sales (serving Vlan 3) it works well (the correct DHCP address in network 192.168.2.x is provided).
    The only way i have found to make the Vlan 2 works is:
    I assigned an ip address to the IAP on the 192.168.1.x (belonging to the Vlan 2)
    I modified the Cisco switch port  excluding the Vlan 1 and making the Vlan 2 native (untagged). Then i modified the static assignment of the network SSID Office from Vlan 2 to Vlan 1. It is really weird, because in the Cisco trunk port Vlan 1 is not allowed (i have Vlan 2 untagged and Vlan 3 tagged), i didn't use a packet analyzer but it seems the Vlan 1 and 2 are reverted. Strange but it works.
    Any idea about this weird behaviour ?
  • 2.  RE: IAP Vlans ID Mismatch
    Posted Sep 11, 2016 05:01 PM
    What is the default gateway of your clients?
  • 3.  RE: IAP Vlans ID Mismatch
    Posted Sep 11, 2016 05:06 PM
    Cisco switch works on L3, so in my case i have :
    Net 192.168.1.0 Def Gateway 192.168.1.1
    Net 192.168.2.0 Def Gateway 192.168.2.1
  • 4.  RE: IAP Vlans ID Mismatch
    Posted Sep 11, 2016 05:18 PM
    What you should do, is do a dhcp debug packet dump to ensure that the client is indeed requesting dhcp packets:  https://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-enable-packet-trace-to-debug-DHCP-packets-in-Instant/ta-p/179952
  • 5.  RE: IAP Vlans ID Mismatch
    Posted Sep 11, 2016 07:23 PM
    I did some debug on both setup.
    First setup (NOT WORKING).
    Cisco switch uplink port in trunk mode, Vlan 1 untagged (native), Vlan 2-3 tagged.
    IAP IP address 192.168.0.5 i guess in Vlan 1 (ad by default IAP settings).
    SSID Office Vlan 2 DHCP pool 192.168.1.x (assigned by Cisco switch), not working.
    SSID Sales Vlan 3 DHCP pool 192.168.1.x (assigned by Cisco switch),  working.
    DHCP debug info on a client (desktop) :
    WIFIAD01# debug pkt mac 04:69:f8:dd:6f:1f
    WIFIAD01# debug pkt match mac
    WIFIAD01# debug pkt type dhcp
    WIFIAD01# debug pkt dump
    If source or destination MAC is 04:69:f8:dd:6f:1f
    AND packet is of type DHCP
    Press 'q' to quit.
    Received packet from aruba101 (timestamp (116-8-11 22:31:15:184176) )
    [asap_firewall_forward(5048):firewall entry] len 342, vlan 0, egress CP, ingress aruba101:
    #mac: etype 0800 smac 04:69:f8:dd:6f:1f dmac ff:ff:ff:ff:ff:ff
    #ip: sip 0.0.0.0, dip 255.255.255.255, proto 17, dscp 48, fragment ok, last fragment, fragment offset 0
    #udp: sport 68 dport 67 len 308
    #dhcp: message-type: request
    hardware type: 1, len: 6, hops: 0
    txn id: 0xabc2874b, seconds elapsed: 10
    client mac: 04:69:f8:dd:6f:1f
    magic cookie: 0x63825363
    #dhcp-option: message-type: discover
    [asap_firewall_forward(5218):vlan decision] len 342, vlan 2, egress CP, ingress aruba101:
    [asap_firewall_check_dhcp_packet(2386):dhcp packet from client] len 342, vlan 2, egress CP, ingress aruba101:
    [asap_firewall_forward(5583):looking up bridge entry] len 342, vlan 2, egress CP, ingress aruba101:
    [asap_firewall_forward(5894):bridge section] len 342, vlan 2, egress CP, ingress aruba101:
    [asap_firewall_forward(6023):session section] len 342, vlan 2, egress vlan 2, ingress aruba101:
    [asap_firewall_forward(6217):fastpath returned 1 opcode 4] len 342, vlan 2, egress vlan 2, ingress aruba101:
    [asap_firewall_forward(6249):slowpath section: opcode 4] len 342, vlan 2, egress vlan 2, ingress aruba101:
    [asap_firewall_forward(6485):back to fastpath, opcode 3] len 342, vlan 2, egress vlan 2, ingress aruba101:
    [asap_firewall_forward(6789):route section] len 342, vlan 2, egress vlan 2, ingress aruba101:
    [asap_firewall_forward(6839):cp route section] len 342, vlan 2, egress vlan 2, ingress aruba101:
    [asap_firewall_forward(7122):forward section] len 342, vlan 2, egress vlan 2, ingress aruba101:
    [asap_firewall_flood(8476):flooding] len 342, vlan 2, egress vlan 2, ingress aruba101:
    [asap_firewall_flood(8533):adding option 82] len 342, vlan 2, egress vlan 2, ingress aruba101:
    [asap_firewall_add_rem_dhcp_option82(8125):returning w/o adding option 82] len 342, vlan 2, egress vlan 2, ingress aruba101:
    [asap_firewall_add_vlan_to_dhcp(8313):adding vlan to dhcp] len 342, vlan 2, egress vlan 2, ingress aruba101:
    [asap_firewall_add_vlan_to_dhcp(8354):added vlan to dhcp] len 346, vlan 2, egress vlan 2, ingress aruba101:
    #udp: sport 68 dport 67 len 312
    #dhcp-option: aruba-vlan: 2
    [asap_firewall_flood(9208):stack section protocol=0x8ffb, type=1] len 346, vlan 2, egress vlan 2, ingress aruba101:
    [asap_firewall_send_up_stack(3316):going to stack protocol:0x8ffb type:1] len 332, vlan 2, egress vlan 2, ingress br0:
    Received packet from aruba101 (timestamp (116-8-11 22:31:16:242876) )
    txn id: 0xabc2874b, seconds elapsed: 11
    Received packet from aruba101 (timestamp (116-8-11 22:31:18:795360) )
    txn id: 0xabc2874b, seconds elapsed: 13
    Received packet from aruba101 (timestamp (116-8-11 22:31:23:670524) )
    txn id: 0xabc2874b, seconds elapsed: 18
    END OF DEBUG INFO
    Second setup ( WORKING).
    Cisco switch uplink port in trunk mode, Vlan 2 untagged (native), Vlan 3 tagged.
    IAP IP address 192.168.1.5.
    SSID Office Vlan 1 DHCP pool 192.168.1.x (assigned by Cisco switch),  working.
    Press 'q' to quit.
    Received packet from bond0 (timestamp (116-8-11 22:19:34:620470) )
    [asap_firewall_forward(5048):firewall entry] len 286, vlan 0, egress CP, ingress bond0:
      #mac: etype 0800 smac 24:01:c7:03:72:09 dmac 04:69:f8:dd:6f:1f
      #ip: sip 192.168.1.1, dip 192.168.1.151, proto 17, dscp 56, fragment ok, last fragment, fragment offset 0
        #udp: sport 67 dport 68 len 252
          #dhcp: message-type: reply
                 hardware type: 0, len: 0, hops: 0
                 txn id: 0x00000000, seconds elapsed: 0
                 your ip: 192.168.1.151
          #dhcp-option: message-type: nack
    [asap_firewall_forward(5218):vlan decision] len 286, vlan 1, egress CP, ingress bond0:
    [asap_firewall_check_dhcp_packet(2426):dhcp packet to client] len 286, vlan 1, egress CP, ingress bond0:
    [asap_firewall_forward(5583):looking up bridge entry] len 286, vlan 1, egress CP, ingress bond0:
    [asap_firewall_forward(5894):bridge section] len 286, vlan 1, egress CP, ingress bond0:
    [asap_firewall_forward(6023):session section] len 286, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_forward(6217):fastpath returned 1 opcode 4] len 286, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_forward(6249):slowpath section: opcode 4] len 286, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_forward(6485):back to fastpath, opcode 3] len 286, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_forward(6789):route section] len 286, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_forward(6839):cp route section] len 286, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_forward(7122):forward section] len 286, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_flood(8476):flooding] len 286, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_flood(8675):checking dev8 bond0] len 286, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_flood(8675):checking dev20 aruba101] len 286, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_flood(9190):flooding to aruba101] len 286, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_flood(9208):stack section protocol=0x800, type=3] len 286, vlan 1, egress vlan 1, ingress bond0:
    Press 'q' to quit.
    Received packet from aruba001 (timestamp (116-8-11 22:21:31:938246) )
    [asap_firewall_forward(5048):firewall entry] len 342, vlan 0, egress CP, ingress aruba001:
                 txn id: 0xabc28749, seconds elapsed: 0
    [asap_firewall_forward(5218):vlan decision] len 342, vlan 1, egress CP, ingress aruba001:
    [asap_firewall_check_dhcp_packet(2386):dhcp packet from client] len 342, vlan 1, egress CP, ingress aruba001:
    [asap_firewall_forward(5583):looking up bridge entry] len 342, vlan 1, egress CP, ingress aruba001:
    [asap_firewall_forward(5894):bridge section] len 342, vlan 1, egress CP, ingress aruba001:
    [asap_firewall_forward(6023):session section] len 342, vlan 1, egress vlan 1, ingress aruba001:
    [asap_firewall_forward(6217):fastpath returned 1 opcode 4] len 342, vlan 1, egress vlan 1, ingress aruba001:
    [asap_firewall_forward(6249):slowpath section: opcode 4] len 342, vlan 1, egress vlan 1, ingress aruba001:
    [asap_firewall_forward(6485):back to fastpath, opcode 3] len 342, vlan 1, egress vlan 1, ingress aruba001:
    [asap_firewall_forward(6789):route section] len 342, vlan 1, egress vlan 1, ingress aruba001:
    [asap_firewall_forward(6839):cp route section] len 342, vlan 1, egress vlan 1, ingress aruba001:
    [asap_firewall_forward(7122):forward section] len 342, vlan 1, egress vlan 1, ingress aruba001:
    [asap_firewall_flood(8476):flooding] len 342, vlan 1, egress vlan 1, ingress aruba001:
    [asap_firewall_flood(8675):checking dev8 bond0] len 342, vlan 1, egress vlan 1, ingress aruba001:
    [asap_firewall_flood(9190):flooding to bond0] len 342, vlan 1, egress vlan 1, ingress aruba001:
    [asap_firewall_flood(8675):checking dev19 aruba001] len 342, vlan 1, egress vlan 1, ingress aruba001:
    [asap_firewall_flood(8675):checking dev20 aruba101] len 342, vlan 1, egress vlan 1, ingress aruba001:
    [asap_firewall_flood(9208):stack section protocol=0x800, type=1] len 342, vlan 1, egress vlan 1, ingress aruba001:
    Received packet from bond0 (timestamp (116-8-11 22:21:31:941370) )
    [asap_firewall_forward(5048):firewall entry] len 351, vlan 0, egress CP, ingress bond0:
        #udp: sport 67 dport 68 len 317
          #dhcp-option: netmask: 255.255.255.0
          #dhcp-option: router: 192.168.1.1
          #dhcp-option: dns-server: 192.168.1.22
          #dhcp-option: dns-name: xxxxxxxx
          #dhcp-option: message-type: offer
          #dhcp-option: dhcp-server: 192.168.1.1
    [asap_firewall_forward(5218):vlan decision] len 351, vlan 1, egress CP, ingress bond0:
    [asap_firewall_check_dhcp_packet(2426):dhcp packet to client] len 351, vlan 1, egress CP, ingress bond0:
    [asap_firewall_forward(5583):looking up bridge entry] len 351, vlan 1, egress CP, ingress bond0:
    [asap_firewall_forward(5894):bridge section] len 351, vlan 1, egress CP, ingress bond0:
    [asap_firewall_forward(6023):session section] len 351, vlan 1, egress aruba001, ingress bond0:
    [asap_firewall_forward(6217):fastpath returned 1 opcode 4] len 351, vlan 1, egress aruba001, ingress bond0:
    [asap_firewall_forward(6249):slowpath section: opcode 4] len 351, vlan 1, egress aruba001, ingress bond0:
    [asap_firewall_forward(6485):back to fastpath, opcode 3] len 351, vlan 1, egress aruba001, ingress bond0:
    [asap_firewall_forward(6789):route section] len 351, vlan 1, egress aruba001, ingress bond0:
    [asap_firewall_forward(6839):cp route section] len 351, vlan 1, egress aruba001, ingress bond0:
    [asap_firewall_forward(7122):forward section] len 351, vlan 1, egress aruba001, ingress bond0:
    [asap_firewall_forward(7439):forwarding packet to aruba001] len 351, vlan 1, egress aruba001, ingress aruba001:
    Received packet from aruba001 (timestamp (116-8-11 22:21:32:955272) )
                 txn id: 0xabc28749, seconds elapsed: 1
          #dhcp-option: requested-ip: 192.168.1.151
          #dhcp-option: message-type: request
    Received packet from bond0 (timestamp (116-8-11 22:21:32:957771) )
          #dhcp-option: message-type: ack
    [asap_firewall_check_dhcp_packet(2467):Send dhcp user(192.168.1.151) to STM and create the L3 user] len 351, vlan 1, egress CP, ingress bond0:
    [asap_firewall_check_dhcp_packet(2484):Created L3 user] len 351, vlan 1, egress CP, ingress bond0:
    END OF DEBUG INFO
    I noticed that in the first case (not working) the received packets are on "aruba101" interface and in the second one (working) the received packets are on "bond0" interface.
    Any idea ?
