IAP-VPN and vpnpsk
  • 1.  IAP-VPN and vpnpsk
    MVP GURU
    Posted Jun 29, 2017 12:49 PM
    i try to use IAP and IAP-VPN with psk mode
    vpn ikepsk sharedkey username myuser password mypassword
    But the tunnel don't work (after 60sec -> retrying)
    show vpn status
    profile name:default
    current using tunnel                            :primary tunnel
    current tunnel using time                       :5 seconds
    ipsec is preempt status                         :disable
    ipsec is fast failover status                   :disable
    ipsec hold on period                            :600s
    ipsec tunnel monitor frequency (seconds/packet) :5
    ipsec tunnel monitor timeout by lost packet cnt :6
    ipsec     primary tunnel crypto type            :PSK
    ipsec     primary tunnel peer address           :10.44.XX.XX
    ipsec     primary tunnel peer tunnel ip         :1.1.1.127
    ipsec     primary tunnel ap tunnel ip           :192.168.253.71
    ipsec     primary tunnel using interface        :tun0
    ipsec     primary tunnel using MTU              :1230
    ipsec     primary tunnel current sm status      :Up
    ipsec     primary tunnel tunnel status          :Up
    ipsec     primary tunnel tunnel retry times     :2
    ipsec     primary tunnel tunnel uptime          :5 seconds
    with cert mode, working
    The peer ip is very strange (i get peer tunnel address with cert mode)
    Any idea ?
  • 2.  RE: IAP-VPN and vpnpsk
    MVP GURU
    Posted Jun 29, 2017 12:52 PM
    the controller log :
    Jun 29 19:41:19  authmgr[2218]: <522005> <INFO> |authmgr|  MAC=00:00:00:00:00:00 IP=192.168.253.65 User entry deleted: reason=idle timeout
    Jun 29 19:41:19  authmgr[2218]: <522013> <INFO> |authmgr|  MAC=00:00:00:00:00:00 IP=192.168.253.65 IP DN: outerIP=10.44.Y.Y tunnels=9
    Jun 29 19:41:19  isakmpd[2080]: <103056> <INFO> |ike|  IKE XAuth client down IP:192.168.253.65 External 10.44.Y.Y
    Jun 29 19:41:39  authmgr[2218]: <124003> <INFO> |authmgr|  Authentication result=Authentication Successful(0), method=VPN, server=Internal, user=10.44.Y.Y
    Jun 29 19:41:39  authmgr[2218]: <124038> <INFO> |authmgr|  Reused server Internal for method=VPN; user=mysuser,  essid=<>, domain=<>, server-group=default
    Jun 29 19:41:39  authmgr[2218]: <522006> <INFO> |authmgr|  MAC=00:00:00:00:00:00 IP=192.168.253.74 User entry added: reason=VPN
    Jun 29 19:41:39  authmgr[2218]: <522008> <NOTI> |authmgr|  User Authentication Successful: username=mysuser MAC=00:00:00:00:00:00 IP=192.168.253.74 role=guest VLAN=0 AP=N/A SSID=N/A AAA profile=default auth method=VPN auth server=Internal
    Jun 29 19:41:39  authmgr[2218]: <522012> <INFO> |authmgr|  MAC=00:00:00:00:00:00 IP=192.168.253.74 IP UP: outerIP=10.44.Y.Y tunnels=9
    Jun 29 19:41:39  authmgr[2218]: <522017> <INFO> |authmgr|  MAC=00:00:00:00:00:00 IP=?? Derived role 'guest' from server rules: server-group=default, authentication=VPN
    Jun 29 19:41:39  authmgr[2218]: <522038> <INFO> |authmgr|  username=mysuser MAC=00:00:00:00:00:00 IP=10.44.Y.Y Authentication result=Authentication Successful method=VPN server=Internal
    Jun 29 19:41:39  authmgr[2218]: <522049> <INFO> |authmgr|  MAC=00:00:00:00:00:00,IP=0.0.0.0 User role updated, existing Role=none/none, new Role=logon/none, reason=IP user created
    Jun 29 19:41:39  authmgr[2218]: <522049> <INFO> |authmgr|  MAC=00:00:00:00:00:00,IP=192.168.253.74 User role updated, existing Role=logon/none, new Role=logon/guest, reason=User authenticated with auth type:VPN client role derivation:0
    Jun 29 19:41:39  authmgr[2218]: <522050> <INFO> |authmgr|  MAC=00:00:00:00:00:00,IP=10.44.Y.Y User data downloaded to datapath, new Role=logon/2, bw Contract=0/0, reason=IP up for non VPN transport for external user, idle-timeout=300
    Jun 29 19:41:39  authmgr[2218]: <522050> <INFO> |authmgr|  MAC=00:00:00:00:00:00,IP=192.168.253.74 User data downloaded to datapath, new Role=guest/4, bw Contract=0/0, reason= IP up for non VPN transport, idle-timeout=300
    Jun 29 19:41:39  isakmpd[2080]: <103015> <INFO> |ike|  IKE Main Mode Phase 1 succeeded for peer 10.44.Y.Y
    Jun 29 19:41:39  isakmpd[2080]: <103022> <INFO> |ike|  IKE Quick Mode succeeded for peer 10.44.Y.Y
    Jun 29 19:41:39  isakmpd[2080]: <103033> <INFO> |ike|  IKE Quick Mode succeeded internal 192.168.253.74, external 10.44.Y.Y
    Jun 29 19:41:39  isakmpd[2080]: <103047> <INFO> |ike|  IKE XAuth succeeded for 192.168.253.74 (External 10.44.Y.Y) for guest
    Jun 29 19:41:39  localdb[2253]: <133004> <INFO> |localdb|  Received Authentication Request for User mysuser
    Jun 29 19:41:39  localdb[2253]: <133005> <INFO> |localdb|  User mysuser guest Successfully Authenticated
  • 3.  RE: IAP-VPN and vpnpsk
    Posted Jan 12, 2018 12:53 AM
    I'm trying to establish VPN connection between StrongSwan and IAP.
    I got this strange situation too.
    Tunnel resets itself at every 45 seconds. There is not meaningful logs at StrongSwan side.
    IAP gets "1.1.1.127" as ipsec primary tunnel peer tunnel ip. I asked this "1.1.1.127" IP at StrongSwan email group too. In conclusion, they said that this situation related with IAP.
    Do you have any idea? I can send more logs from IAP if you need.
    Thanks for help.
    # show vpn status
    current tunnel using time :19 seconds
    ipsec primary tunnel peer address :X.X.X.X
    ipsec primary tunnel ap tunnel ip :10.99.0.10
    ipsec primary tunnel tunnel uptime :20 seconds
    ipsec backup tunnel crypto type :PSK
    ipsec backup tunnel peer address :N/A
    ipsec backup tunnel peer tunnel ip :N/A
    ipsec backup tunnel ap tunnel ip :N/A
    ipsec backup tunnel using interface :N/A
    ipsec backup tunnel using MTU :N/A
    ipsec backup tunnel current sm status :Init
    ipsec backup tunnel tunnel status :Down
    ipsec backup tunnel tunnel retry times :0
    ipsec backup tunnel tunnel uptime :0
  • 4.  RE: IAP-VPN and vpnpsk
    Posted Jan 12, 2018 03:50 AM
    We have updated IAP image version from "6.5.1.0-4.3.1.2" to "6.5.3.4" and connection reset problem solved!
    The root cause is IAP thinks StrongSwan as controller and making requests in every 3 seconds like:
    2018-01-12 06:20:51 cli_rap_reg_request(3162) sending reg-request to 1.1.1.127 : iap/register?branch_key=bc3569e10117fdcaf2b8186220e32a72fc09f7a3604a9606f2&&subnet_count=0&is_backup=no&is_data_controller=no&is_trusted_branch=no&mac_addr=84d47ec4ce36&branch_name=central-demo with tun_idx 0 retry-counter 9, not-trusted: local-mgmt-mode
    2018-01-12 06:20:54 cli_rap_reg_request(3162) sending reg-request to 1.1.1.127 : iap/register?branch_key=bc3569e10117fdcaf2b8186220e32a72fc09f7a3604a9606f2&&subnet_count=0&is_backup=no&is_data_controller=no&is_trusted_branch=no&mac_addr=84d47ec4ce36&branch_name=central-demo with tun_idx 0 retry-counter 10, not-trusted: local-mgmt-mode
    2018-01-12 06:20:57 cli_rap_reg_request(3162) sending reg-request to 1.1.1.127 : iap/register?branch_key=bc3569e10117fdcaf2b8186220e32a72fc09f7a3604a9606f2&&subnet_count=0&is_backup=no&is_data_controller=no&is_trusted_branch=no&mac_addr=84d47ec4ce36&branch_name=central-demo with tun_idx 0 retry-counter 11, not-trusted: local-mgmt-mode
    2018-01-12 06:21:00 cli_rap_reg_request(3162) sending reg-request to 1.1.1.127 : iap/register?branch_key=bc3569e10117fdcaf2b8186220e32a72fc09f7a3604a9606f2&&subnet_count=0&is_backup=no&is_data_controller=no&is_trusted_branch=no&mac_addr=84d47ec4ce36&branch_name=central-demo with tun_idx 0 retry-counter 12, not-trusted: local-mgmt-mode
    2018-01-12 06:21:03 cli_rap_reg_request(3162) sending reg-request to 1.1.1.127 : iap/register?branch_key=bc3569e10117fdcaf2b8186220e32a72fc09f7a3604a9606f2&&subnet_count=0&is_backup=no&is_data_controller=no&is_trusted_branch=no&mac_addr=84d47ec4ce36&branch_name=central-demo with tun_idx 0 retry-counter 13, not-trusted: local-mgmt-mode
    2018-01-12 06:21:06 cli_rap_reg_request(3162) sending reg-request to 1.1.1.127 : iap/register?branch_key=bc3569e10117fdcaf2b8186220e32a72fc09f7a3604a9606f2&&subnet_count=0&is_backup=no&is_data_controller=no&is_trusted_branch=no&mac_addr=84d47ec4ce36&branch_name=central-demo with tun_idx 0 retry-counter 14, not-trusted: local-mgmt-mode
    2018-01-12 06:21:09 cli_rap_reg_request(3162) sending reg-request to 1.1.1.127 : iap/register?branch_key=bc3569e10117fdcaf2b8186220e32a72fc09f7a3604a9606f2&&subnet_count=0&is_backup=no&is_data_controller=no&is_trusted_branch=no&mac_addr=84d47ec4ce36&branch_name=central-demo with tun_idx 0 retry-counter 15, not-trusted: local-mgmt-mode
    2018-01-12 06:21:12 [primary tunnel] ipsec_tunnel_monitor_action(2539): tunnel down be checked, controller 1.1.1.127
    2018-01-12 06:21:12 [primary tunnel] tunnel_status_monitor_timeout(1085): monitor primary tunnel down, trigger state machine change.
    2018-01-12 06:21:12 [primary tunnel] State TUNNEL_STATE_UP Event TUNNEL_EVENT_TUNNEL_DOWN Next state TUNNEL_STATE_DOWN
    2018-01-12 06:21:12 [primary tunnel] tunnel_down(397): primary tunnel tunnel down.
    2018-01-12 06:21:12 [primary tunnel] ipsec_tunnel_down(2063): Tunnel primary tunnel down.
    2018-01-12 06:21:12 tunnel_set_status_to_asap(177): Set ipsec tunnel status =0 0
    We still does not know why IAP peer tunnel ip is "1.1.1.127". IAP can not ping 1.1.1.127. (Probably it is normal)
    When IAP making requests to "1.1.1.127" and can not access it marks the VPN connections as lost and resets the connection.
    After upgrading to IAP image, IAP still makes connection requests to "1.1.1.127" but in every 1 minutes. (instead of every 3 seconds) Making requests in every 1 minute prevents IAP to mark VPN connections as down.
    2018-01-12 07:30:13 cli_rap_reg_request(3165) sending reg-request to 1.1.1.127 : iap/register?branch_key=bc3569e10117fdcaf2b8186220e32a72fc09f7a3604a9606f2&&subnet_count=0&is_backup=no&is_data_controller=no&is_trusted_branch=no&mac_addr=84d47ec4ce36&branch_name=central-demo with tun_idx 0 retry-counter 41, not-trusted: local-mgmt-mode
    2018-01-12 07:31:18 cli_rap_reg_request(3165) sending reg-request to 1.1.1.127 : iap/register?branch_key=bc3569e10117fdcaf2b8186220e32a72fc09f7a3604a9606f2&&subnet_count=0&is_backup=no&is_data_controller=no&is_trusted_branch=no&mac_addr=84d47ec4ce36&branch_name=central-demo with tun_idx 0 retry-counter 42, not-trusted: local-mgmt-mode
    2018-01-12 07:32:25 cli_rap_reg_request(3165) sending reg-request to 1.1.1.127 : iap/register?branch_key=bc3569e10117fdcaf2b8186220e32a72fc09f7a3604a9606f2&&subnet_count=0&is_backup=no&is_data_controller=no&is_trusted_branch=no&mac_addr=84d47ec4ce36&branch_name=central-demo with tun_idx 0 retry-counter 43, not-trusted: local-mgmt-mode
    2018-01-12 07:33:36 cli_rap_reg_request(3165) sending reg-request to 1.1.1.127 : iap/register?branch_key=bc3569e10117fdcaf2b8186220e32a72fc09f7a3604a9606f2&&subnet_count=0&is_backup=no&is_data_controller=no&is_trusted_branch=no&mac_addr=84d47ec4ce36&branch_name=central-demo with tun_idx 0 retry-counter 44, not-trusted: local-mgmt-mode
    2018-01-12 07:34:50 cli_rap_reg_request(3165) sending reg-request to 1.1.1.127 : iap/register?branch_key=bc3569e10117fdcaf2b8186220e32a72fc09f7a3604a9606f2&&subnet_count=0&is_backup=no&is_data_controller=no&is_trusted_branch=no&mac_addr=84d47ec4ce36&branch_name=central-demo with tun_idx 0 retry-counter 45, not-trusted: local-mgmt-mode
    Why IAP gets "1.1.1.127" as peer tunnel ip?
    Why IAP making that request to "1.1.1.127"
    The VPN connection logs about getting "1.1.1.127" as peer tunnel ip is:
    2018-01-12 06:36:21 [primary tunnel] cli_proc_rapper_msg(864): Receive rapper msg from 59168 port.
    2018-01-12 06:36:21 [cli_proc_rapper_msg] No Inner IP of Controller found. Its a non Aruba concentrator.Assgning the Concentrator's inner IP as 7f010101
    2018-01-12 06:36:21 [primary tunnel] Received RC_OPCODE_PPP_UP lms XX.55.49.104 netmask 0.0.0.0 tunnel 10.99.0.1
    2018-01-12 06:36:21 [primary tunnel] tunnel_up_msg_recv(1488): recv tunnel up msg, device tun0, rapper client port 8423, peer ip XX.55.49.104, tunnel ip 10.99.0.1 net mask 0.0.0.0, controller ip 1.1.1.127.
    Hex to ip converter says that "7f010101" is "127.1.1.1" (Not 1.1.1.127)
    Thanks for any help or comment.
  • 5.  RE: IAP-VPN and vpnpsk
    Posted Jan 12, 2018 04:01 AM
    We have updated IAP version form "6.5.1.0-4.3.1.2" to "6.5.3.4" and connection reset problem solved.
    Before upgrading IAP making requests to "1.1.1.127" in every 3 seconds:
    IAP can not ping the 1.1.1.127 (Probably it is normal?) After trying enough requests to 1.1.1.127, IAP marks VPN connection as down and resets the connection.
    After upgrading IAP image version to 6.5.3.4, IAP still thinks StrongSwan as controller and making requests to "1.1.1.127" address in every 1 minutes. Frequency of this unsuccessful requests are decreased and this solved VPN connection reset problem.
    The logs about getting "1.1.1.127" as peer tunnel ip is:
    2018-01-12 06:36:21 [primary tunnel] Received RC_OPCODE_PPP_UP lms X.55.49.104 netmask 0.0.0.0 tunnel 10.99.0.1
    2018-01-12 06:36:21 [primary tunnel] tunnel_up_msg_recv(1488): recv tunnel up msg, device tun0, rapper client port 8423, peer ip X.55.49.104, tunnel ip 10.99.0.1 net mask 0.0.0.0, controller ip 1.1.1.127.
    Why IAP gets "1.1.1.127" as ap peer tunnel ip?
    Why IAP making requests to "1.1.1.127" (IAP thinks StrongSwan as controller?)
    Logs say that "No Inner IP of Controller found. Its a non Aruba concentrator.Assgning the Concentrator's inner IP as 7f010101". Hex to ip conversion for "7f010101" is "127.1.1.1" (NOT 1.1.1.127)
    Thanks for helps and any comments.
  • 6.  RE: IAP-VPN and vpnpsk
    MVP GURU
    Posted Jan 15, 2018 03:55 AM
    and the tunnel work ?
    What your configuration ?
  • 7.  RE: IAP-VPN and vpnpsk
    Posted Jan 18, 2018 08:19 AM
    Yes, tunnel works.
