IAP-VPN (GUEST VLAN) Best Design
This thread has been viewed 30 times
  • 1.  IAP-VPN (GUEST VLAN) Best Design
    Posted Dec 31, 2020 04:14 AM
    I'm working to deploy a IAP-VPN just for GUEST vlan with portal in DC.
    My customer wants to have only one vlan for all remotes sites (100) in DC, I suppose the best choice is Centralized L2 or L3.
    What is the best design ?
    G_lepers
  • 2.  RE: IAP-VPN (GUEST VLAN) Best Design
    Posted Jan 03, 2021 12:39 AM
    As per the Instant VRD, the recommended/most common modes of deployments are Centralized Layer 2 or Distributed Layer 3..
    In your case, where do you want the gateway of this subnet to be? Do you need the branches to be layer 2 connected and have the gateway in DC? If yes, then you can go with CL2.. Check pages 53-60 in the VRD..
    https://community.arubanetworks.com/browse/articles/blogviewer?BlogKey=1f47bc48-dafb-4b48-9ff1-2973bb3c2f87
    Ayman Mukaddam
  • 3.  RE: IAP-VPN (GUEST VLAN) Best Design
    Posted Jan 07, 2021 12:34 PM
    In my case I design Centralized L2 (DHCP and gateway in DC), I pushed GUEST in IPSec tunnel directly.
    Thank you for your answer.
    G_lepers
