IAP VPN Virtual Controller
This thread has been viewed 34 times
  • 1.  IAP VPN Virtual Controller
    Posted Apr 07, 2022 09:54 AM
    Om trying to set up a IAP vpn to a Virtual controller managed in Aruba Central.
    The accesspoint is also Central managed but placed in a different account than the Virtual Controller.
    The vpn won't be established.
    The log shows "User Authentication failed. username=xx-xx-xx-xx-xx-xx"
    I have added the mac address to whitelist-db rap. Doesn't help.
    Any ideas?
    J
  • 2.  RE: IAP VPN Virtual Controller
    Posted Apr 13, 2022 06:50 PM
    Your controller acting as VPN head-end, should be running a SD-WAN firmware and should be in the same Aruba Central account as that of your IAPs.
    otherwise it will not work.
  • 3.  RE: IAP VPN Virtual Controller
    Posted Apr 14, 2022 06:49 AM
    Give a try to add it to trusted branch db...
    On the controler,
    iap trusted-branch-db add mac-address xx-xx-xx-xx-xx-xx
    Pat
    Patrick Casavant
