last person joined: 3 hours ago
IAP VPN with VNet Gateway
  • 1.  IAP VPN with VNet Gateway
    Posted Jul 13, 2020 06:22 AM
    Hi, Is it supported in IAP to create a IPsex tunnel with Azure VNet Gateway instead of vGW from Aruba ?
  • 2.  RE: IAP VPN with VNet Gateway
    Posted Jul 13, 2020 07:56 PM
    IAPs an create IPSEC tunnels with any 3rd party server that supports a minimum of PSK based authentication on IKEv1.
    this will be  manual configuration process and there are lots of advantages to use Aruba's vGW instead, not only from configuration but also from monitoring and reporting
