iAP walled - garden
  • 1.  iAP walled - garden
    Posted Oct 30, 2018 05:26 AM
    Hi @ all,
    Can someone help me?
    I search the walled-garden in the menu ????
    that should be in the menu security
    (iAP 8.3.0.3)
    thanks tom
  • 2.  RE: iAP walled - garden
    MVP EXPERT
    Posted Oct 30, 2018 05:31 AM
    Are you using an External Captive Portal?
    The walled garden access is required when an external captive portal is used.
    Also have you tried adding it via the CLI?
    (Instant AP)(config)# wlan walled-garden
    (Instant AP)(Walled Garden)# white-list <domain>
    (Instant AP)(Walled Garden)# black-list <domain>
  • 3.  RE: iAP walled - garden
    Posted Oct 30, 2018 06:45 AM
    OK thanks
    I can also achieve this with the internal guest portal (captive portal)
    I would like to have a link on the portal page, e.g. for AGB / infos deposit.
    So that a guest can access this server before logging in
    tom
  • 4.  RE: iAP walled - garden
    MVP EXPERT
    Posted Oct 30, 2018 07:02 AM
    I don't believe it is possible to embedded HTML (i assume this will be used for your link...) in the Welcome page of an Instant. You would need Clearpass or similar for this.
