last person joined: 4 hours ago
IAP Wi-Fi Uplink , Eth port suddenly not functiong (light on) but no comm between lan to unit
  • 1.  IAP Wi-Fi Uplink , Eth port suddenly not functiong (light on) but no comm between lan to unit
    Posted May 30, 2016 03:46 AM
    Hi Guys,
    Good morning,
    I have a an issue,
    Please look on the following diagram:
    I connected an AP-103 as a client to an existing Aruba network , the wi-fi uplink working great,I also converted the AP to standalone mode , and marked the SSID not to be turned off when no uplink avilable , so far so good :) MY ISSUE:  any X time if using/moving - the client connected to the IAP ETH port (That is with ETH0 bridge) get disconnected , and it's seems that the wired interface of the AP aint working (it's happning in 3 diffrent AP'S i tested with two diffrent computers connected to the ETH0 of the AP) , i in that moment im connecting to the IAP wireless , everything is working , it's just the wired port that is on but suddenly dosent do no DHCP and even no answering to Static IP pings from client to PC , reseting the unit (IAP ) solving the issue.
    What might causing that? (Spanning tree?) Why the eth0 stop acting as needed while using?
    Please advise .
    Me.
  • 2.  RE: IAP Wi-Fi Uplink , Eth port suddenly not functiong (light on) but no comm between lan to unit
    Posted May 30, 2016 06:42 AM
    What version of instant?
  • 3.  RE: IAP Wi-Fi Uplink , Eth port suddenly not functiong (light on) but no comm between lan to unit
    Posted May 31, 2016 12:29 PM
    It's happend on two diffrent InstantOS's (One of them is: ArubaInstant_Pegasus_6.4.3.4-4.2.1.2_53307 )
    Tommorw i will on site and try to continue debug (And hope to solve the issue) .
    Our Issue: Every once in a while ( Usually couple of minutes)  ETH PORTS seems up but stops doing any traffic to the client pc that connected to the IAP eth port.
    We deployed 3 IAP units , 1 on each cart , the IAP creating a unique SSID for each cart (Different SSID for every cart) on 5GHz 44/44+ channel and ETH0 bridging marked in order to transmit the same VLAN as the cart SSID. Each IAP also connected with Wi-Fi 2.4Ghz uplink to the site Wi-Fi network (WPA2Personal Aruba controller based environment ) – the Wi-Fi uplink is usage for management only. EACH IAP on EACH cart is converted to standalone.
