IAP Wired Port Profile
This thread has been viewed 28 times
  • 1.  IAP Wired Port Profile
    Posted Feb 04, 2021 07:12 AM
    Been a while since I have assigned a Port profile on an IAP that is part of a cluster. I thought you could edit an individual AP directly and assign a profile. Say I have a cluster of 3 AP's. I want to assign different profiles to port E1 differently on each AP. Is this possible? Seems Port Profiles can only be assigned at the Cluster level and all APs will have the same profiles on the ports.
    Central 2.5.1 eludes that this is possible Configuring Ethernet Port Profiles on Instant APs - Section: Configuring Network Port Profile Assignment - Step 3.
    Central 2.5.2 removed this verbiage.
    Local IAP Config (No Central) - Not seeing a way to do it either.
    Philip Wightman, ACEX (AMFX) #69. Aruba Partner Ambassador
  • 2.  RE: IAP Wired Port Profile
    Posted Feb 11, 2021 04:56 PM
    the eth port profile are configured for the whole cluster
  • 3.  RE: IAP Wired Port Profile
    Posted Feb 11, 2021 06:08 PM
    Thank you for the confirmation. I see a feature request in my future.
