IAP with Central on 4G
  • 1.  IAP with Central on 4G
    Posted Jan 07, 2021 03:57 PM
    Hi
    I'm trying to get the Verizon 730L working with the IAP as a backup option. - 303H
    So far its getting detected (after converting into enterprise mode). However it doesnt connect or pass data.
    It doesnt work at all in a failover scenario. At times, if i boot the IAP with the usb alone, it shows up as transferring data (LEDs blinking) but its not really pushing any data through it.
    On my wired uplink it shows the tunnel source IP, but with the 4G its not showing an IP in that field.
    On Wire
    sh ip interface tunnel
    Interface IP Address / IP Netmask Type Tunnel Source Peer Address Peer Tunnel IP L2 VLAN
    tun0 172.28.166.26 / 255.255.255.255 IPSEC 192.168.1.76 20.20.16.2 172.28.183.42 NA
    gre0 NA / NA GRE 172.28.166.26 172.28.183.42 NA 497
    On USB
    tun0 172.28.166.22 / 255.255.255.255 IPSEC 0.0.0.0 20.20.13.2 172.28.183.42 NA
    gre0 NA / NA GRE 172.28.166.22 172.28.183.42 NA 497
    sh cellular status
    Cellular Status
    card detect link SIM PIN
    Present detect-ok Linkup AT+CPIN
    USB Modem Information
    Parameter Value
    Manufacturer Linux
    Product xHCI Host Controller
    Serial Number xhci-hcd.0.auto
    Driver hub
    Vendor ID 1d6b
    Product ID 0003
    Manufacturer Novatel
    Product MiFi USB730L
    Serial Number 0123456789ABCDEF
    Driver option
    Vendor ID 1410
    Product ID 9032
    Model USB730L
    Supported Network Services LTE CDMA LTE WCDMA
    Firmware Version 3.41.1
    ESN Number 990009291637612
    Cellular Link Status
    Parameter Value
    USB Modem State Active
    USB RSSI is failing... N/A
    USB Current Network is not available N/A
    plugin counter :0
    plugout counter :0
    2020-12-15 01:59:52,Cellular uplink is up with IP 100.107.169.244
    2020-12-15 02:00:48,Cellular uplink is down
    2020-12-15 02:02:41,Cellular uplink is up with IP 100.98.101.226
    Is this something to do with nat vs ip passthru in the newer version of the usb ?
    any help is appreciated.....
    SoJee
